1. pinkcamaro17's Avatar
    I'm having issues with my battery I believe it is on my skyrocket. When I first had it it was okay. Now everytime I go to charge my phone it will take forever to charge and then it will randomly stop charging. The battery life is fine its just the charging and then when I am charging it and it says charging if I have to look something up real quick my battery goes down even when charging. Also the other day my phone showed charging so I was watching a few YouTube videos then mybohone completely turned off. I couldn't get it to turn back on and when I plugged my.charger back in all it did was vibrate stop vibrate stop and it even did that when my phone was off the charging but it would never show the battery icon when plugged into the charger it just did that vibrate thing. I'm using all of the original cords to this phone. Anyone know what it is or know if I should call and get a replacement? My phone has been on the charger almost all day and is only at 48%.
    Sent from my SAMSUNG-SGH-I727 using Android Central Forums
    06-14-2012 07:59 PM
  2. rgarcia900's Avatar
    do you have another USB cable to use with the charger? do you have a car charger? and if so. does it happen with both?
    06-14-2012 08:23 PM
  3. rgarcia900's Avatar
    Also try charging and transferring files using your PC and USB cable. If you get errors while transferring files, it could mean a bad cable (or a damaged USB port on your phone).
    If it works fine and charges fine, then it is your charger.
    Was your phone dropped? was the cable yanked off the phone or was it hit while connected to the cable? that could damage the USB port on your phone too...
    06-14-2012 08:28 PM
  4. pinkcamaro17's Avatar
    I think it maybe my USB because I plugged it into the car and it did fine. It seems my USB for the home charger is a little loose but my car charger wasn't.
    06-14-2012 09:43 PM
  5. rgarcia900's Avatar
    USB cable or USB Charger? cables are cheap on ebay or computer store, or you might have one from an older phone and will work.
    I use the same USB cable for a BlackBerry Torch, HTC Inspire, Samsung Skyrocket, Nook and Kindle.
    If it's the original samsung charger, you might be able to exchange it within the 1yr warranty at an authorized AT&T repair center, unless it is obvious neglect.
    06-14-2012 10:10 PM
  6. rgarcia900's Avatar
    Is it the original samsung?
    06-14-2012 10:45 PM
  7. pinkcamaro17's Avatar
    I think the cable is fine because it.charges when plugged into the computer so I think its that little box thing that you plug into the wall and yes its original.
    06-15-2012 03:46 AM
  8. spddy's Avatar
    Your pc will work but it will take longer to charge.
    06-15-2012 05:27 AM
