1. buffee's Avatar
    I have a Captivate right now(grrr) and it has an 8G memory card in it. I will be getting thr skyrocket in the next couple weeks and want 16G...how do I get all the stuff off of the 8 onto the 16? I appreciate any help. thanks
    06-20-2012 05:42 PM
  2. shinsen1378's Avatar
    Get a 16GB card that comes with a microSD to SD adapter.
    Then find a PC or laptop with an SD slot and copy the info from the 8GB to a new directory on the PC, then from the PC to the 16GB.
    06-20-2012 07:55 PM
