1. Uselessbass's Avatar
    Has anybody tried the power saving mode in ice cream sandwich and if so did it make much of a difference I'm trying it right now and it definitely throttles your cpu I can tell just by swiping home screens lol but if it saves me some juice I'll sacrafice
    Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
    07-12-2012 08:51 PM
  2. Superman4060's Avatar
    I am using it as of yesterday and its increasing my batter life by a couple hours. it basically turns off everything that you may not need. that includes sync. which is the biggest drain in my opinion i have mine set at 50%.
    Uselessbass likes this.
    07-12-2012 11:44 PM
  3. Uselessbass's Avatar
    Sweet thanks for the info
    07-13-2012 12:16 AM
  4. TvTechGuru's Avatar
    I tried the default saving setting but I'm not sure what it does and it doesn't tell you. It definitely extends life. Haven't tried the custom setting.
    Sent from my SAMSUNG-SGH-I727 using Android Central Forums
    07-13-2012 01:36 AM
