1. bap2510's Avatar
    I'm currently running the att leak (UCLF5) on my rooted skyrocket. I've been using this for a while now. Recently that battery drain has been terrible. This morning I unplugged with a full charge and 3 hours later I was down to 36%. I had the phone sitting on my table and did not use it at all. The drain was something like 24% an hour while in idle. Does anyone have any ideas what could be happening? This does not happen all the time, but just enough to make me wonder. Most of the time my battery drain is around 2% when not in use and around 5 to 6% when I'm using it. Any help would be appreciated. Thanks in advance. I am not in a LTE area.
    08-25-2012 09:48 AM
  2. mrro82's Avatar
    Something is running in the background. Check to see what's running in apps. Also, try juice defender from the store. It's a great app.
    08-25-2012 06:36 PM
