T talelorm Member May 10, 2012 9 0 0 Visit site Mar 21, 2013 #1 I have cm10.1 nightly march 20 and I can't send pictures Any suggestions?
M MrGriffdude Active member Mar 9, 2013 40 0 0 Visit site Mar 21, 2013 #2 talelorm said: I have cm10.1 nightly march 20 and I can't send pictures Any suggestions? Click to expand... Fix permissions if that doesn't work make sure your data settings are correct. If that doesn't work do a clean install and set if that fixes it. Sent from my SAMSUNG-SGH-I727 using Android Central Forums
iFebby Well-known member Aug 4, 2012 233 0 0 Visit site Mar 21, 2013 #3 talelorm said: I have cm10.1 nightly march 20 and I can't send pictures Any suggestions? Click to expand... What carrier? AT&T? If so check your APN settings and if that is correct try using gosms pro to check if that works to see if it might be the MMS apk. Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
T talelorm Member May 10, 2012 9 0 0 Visit site Mar 22, 2013 #4 its been fixed using a clean install thanks
