1. talelorm's Avatar
    ok so I got the skyrocket i727
    I have this charger :Amazon.com: PowerGen Dual USB 3.1A 15w Travel Wall Charger with Swivel plug for Apple iPad 2, New iPad 3, iPhone 5 4s 4 3 3Gs, Amazon Kindle Fire HD DX KeyBoard, Samsung Galaxy Tab (USB Cable NOT included) - BLACK: MP3 Players & Accessories
    and this cable: Amazon.com: AmazonBasics USB Cable - 2.0 A Male to Micro B (6 Feet / 1.8 Meters): Electronics
    with those I get 0.04 amps to 0.07 amps
    using the powergen with stock cable I stick at 0.06 amps
    stock cord and charger get me 0.02 amp to 0.04 amps
    stock charger with amazon cord I get 0.02 amps to 0.07 amps.
    turning the phone off seems to make no difference what so ever. in fact sometimes worse, I tried flashing stock 4.1.2and it helped a little then it boot loops
    I have no problems running cynogenmod and it never did this before on cynagenmod
    whats going on? I tried 2 different OEM batteries
    same amp rates nothing different
    05-21-2013 11:58 PM
  2. Golfdriver97's Avatar
    Are either or both the batteries bulged in the center?
    05-22-2013 12:17 AM
  3. talelorm's Avatar
    no they are both not
    05-22-2013 12:27 AM
  4. Golfdriver97's Avatar
    Another cable/charger set up to test then? If that doesn't work, I am afraid you may have a connector problem in the phone.
    05-22-2013 12:28 AM
  5. talelorm's Avatar
    I used a third stock with a mediabridge cable yielding only 0.07-0.08
    is there any way to fix it if this is true?
    05-22-2013 12:33 AM
  6. Golfdriver97's Avatar
    To fix it, I would guess yes. The question is how, which I do not know.
    05-22-2013 12:39 AM
  7. talelorm's Avatar
    I wonder if I should call Samsung or at&t to see what they say lol
    05-22-2013 12:43 AM
  8. Golfdriver97's Avatar
    That is an option. The worst they are going to say is that they can't do anything for you.
    05-22-2013 08:52 AM
  9. friedtators's Avatar
    There is a known issue. Use an OEM charger.
    05-28-2013 06:42 PM
  10. grenefroggie's Avatar
    What he said. There have been many issues with the Skyrocket and poor charging, as well as the dreaded wakelock which eats your battery.
    05-28-2013 07:30 PM
  11. rnhunsaker's Avatar
    A 2 amp charger solved my problem.
    For my car or for my home, I only have success charging my S2 when I have a 2 amp charger.
    The phone only sucks the power when it needs it, it charges reliably and it stops charging (or slows to a trickle) when it doesn't need the power.
    A 2 amp charger will cost a bit more $$ but it solves a lot of grief.
    06-02-2013 10:05 PM
  1. Umm, I may have a problem, need some help!
    By formula355 in forum LG Optimus S
    Last Post: 04-20-2012, 08:50 PM
  2. My Touch 4g Problem Need Serious help!!
    By jcanchola in forum HTC myTouch 4G
    Last Post: 10-27-2011, 01:04 PM
  3. Optimus s major problems NEED HELP
    By 956jrand in forum New to the Forums? Introduce Yourself Here!
    Last Post: 07-09-2011, 03:41 PM
  4. major rom problems need to flash stock
    By Centro85#AC in forum Droid 2 Rooting, ROMs, and Hacks
    Last Post: 01-26-2011, 01:41 PM
  5. So I have a little problem need some help
    By Cirro in forum Motorola Droid
    Last Post: 05-05-2010, 01:51 PM
