1. bluebo's Avatar
    Read that the sound isnt very good on S2
    can someone confirm this, read earphone not that clear
    is speakphone good and is it loud enough to be able to listen to hoop games on it?
    what are the speakers like
    thanks
    01-12-2012 01:27 AM
  2. jfs101's Avatar
    The ear speaker is very clear. I don't use the speakerphone for calls, I use it a lot to listen to tunein radio while I shower and it's ok. My wife has a Motorola Defy and it's much louder than the Galaxy S2.
    What can I say, it works but don't expect to much from it.
    The included earphone do sound great for multimedia, which you should use in the first place to save some battery juice.
    Sent from my GT-I9100 using Tapatalk
    01-15-2012 08:36 AM
  3. taqri85's Avatar
    The yamaha sound ic on sgs2 isn't very good. Don't expect it to blow you away but its still very very nice.
    01-16-2012 03:51 PM
