1. abualghanam's Avatar
    Guys i am facing problem in locking my phone ... I use pattren or password but it wont works perfectly you can pass the screen lock by pressing the power button twice ... may be this problem comes out when i installed GO luncher and go locker ...thank you !
    09-04-2012 11:04 AM
  2. abualghanam's Avatar
    Still no reply guys ...give a hand here friends
    09-06-2012 09:44 AM
  3. gigley's Avatar
    If you are using go locker you should know that in its setting you'll find an option called "emergency unlock". If it's activated it can bypass the screen lock on your phone in some ways. Just deactive that and the problem will be solved
    if you are using the stock screen lock and this happens something is very wrong with your android installation. I would recommend flashing you device or a factory reset. But dont rush it. Wait to see what others have in mind.
    09-14-2012 06:08 AM
