1. Claire Cn's Avatar
    Hi there! If anyone can help I'll be suuuuuuper grateful.
    Yesterday evening, my phone ran out of battery. When I turned it on again I tried to send a text message but I couldn't open the messaging application. So when I pressed the message icon on the home screen, it went black and then returned to the home screen. When I've tried afterwards, it sometimes gives me a message along the lines of "processcom.messaging.android needs to close" -- i can't remember it exactly but it's something like that - it only flashes up and then goes.
    Any ideas what I can do? People have told me they've sent me text messages but I'm not getting any notifications and can't open the messages at all. I use my phone for texts more than calls, so feeling a little paralysed!
    Thanks for any help at all!!!
    Claire
    03-24-2013 07:23 AM
  2. DroidXcon's Avatar
    Claire
    Try clearing messenger data
    Settings> applications> all> messenger> clear data
    Did you try downloading a third party messaging app from the market like handcent? Let me know if that works.
    From my Galaxy Note 2 via Tapatalk
    03-24-2013 09:14 AM
  3. Claire Cn's Avatar
    Thanks so much for replying! I tried clearing the data but it hasn't helped. I didn't realise you could get third party messaging apps - will they pick up my normal texts? I'll have a go with one =)
    03-24-2013 01:32 PM
  4. Claire Cn's Avatar
    Argh - it doesn't work. It says the same - "The application Handcent SMS (process com.handcent.nextsms) has stopped unexpectedly. Please try again."
    But when I try again, nothing happens.
    03-24-2013 01:39 PM
  5. DroidXcon's Avatar
    Yeah go sms, handcent, chomp, they all mirror stock texts...I use handcent
    I don't know if it will work with the stock app not working but let's see what happens.
    Attached Thumbnails Tech problem with messaging - please help!-uploadfromtaptalk1364150470892.jpg
    03-24-2013 01:41 PM
  6. Claire Cn's Avatar
    Nope ... nothing =(
    03-24-2013 02:36 PM
  7. DroidXcon's Avatar
    Nope ... nothing =(
    Do you have your contacts backed up and your pictures saved to your computer. We may have to do a factory restore
    03-24-2013 02:47 PM
  8. Claire Cn's Avatar
    No, how do I back my contacts up? Pictures/music/files etc backed up.
    03-24-2013 02:51 PM
  9. DroidXcon's Avatar
    Go to settings> accounts> Google> select your google account> then check off all the boxes> hit sync now
    Or you can also open conacts app> menu button> >export to sd card. This will create a contacts file on your sdcard which you can later import
    03-24-2013 04:44 PM
  1. problem with Google Apps.. HELP please
    By SkyReacher in forum Samsung Galaxy S3
    Last Post: 01-27-2013, 12:37 PM
  2. Problem with hotmail sync. Help please!
    By matawo in forum Samsung Galaxy S3
    Last Post: 12-18-2012, 01:02 AM
  3. trouble with root, please help!
    By dannychaos in forum HTC Droid Eris Rooting, ROMs, and Hacking
    Last Post: 03-26-2010, 11:51 PM
  4. Google Maps loading problem with GPS-Need help.
    By arcane#AC in forum HTC Hero
    Last Post: 12-13-2009, 05:18 PM
  5. Problem with task killer HELP!!!!
    By nomadd212 in forum Motorola Droid
    Last Post: 12-12-2009, 01:40 PM
