1. Assaf Levi's Avatar
    Hello everyone
    I have tried everything i could and i have searched everywhere i can think of, and still i can't find anyway to do this.
    thank you
    03-29-2013 06:50 AM
  2. DroidXcon's Avatar
    Hello everyone
    thank you
    You want to turn on or off vibration without the phone actually vibrating?
    From my Galaxy Note 2 via Tapatalk
    03-29-2013 07:01 AM
  3. DroidXcon's Avatar
    03-29-2013 07:02 AM
  4. Assaf Levi's Avatar
    Everytime you switch from ring to vibration the phone will vibrate to notify you about the switch. I want to disable this notification, and let the phone enter the vibration mode silently.
    03-29-2013 07:16 AM
  5. DroidXcon's Avatar
    No idea. I never thought about it before you mentioned it. Ill keep an eye out for you though
    03-29-2013 07:28 AM
  1. How to turn off Notification sound when plugging in
    By dmcrowe in forum Motorola Droid X
    Last Post: 09-25-2013, 09:39 AM
  2. How to disable text msg preview at the top with sound on
    By ariesx in forum Samsung Galaxy Note
    Last Post: 01-22-2013, 03:55 PM
  3. How to disable the nofication sound for USB connection?
    By Rev2010 in forum Motorola Droid 2
    Last Post: 12-19-2011, 10:10 AM
  4. How to disable the Beep after Pattern Unlock!
    By hindibuff in forum Sprint Epic 4G
    Last Post: 04-26-2011, 10:20 AM
  5. How to disable system sounds while chargin!?
    By ywenz in forum Sprint Epic 4G
    Last Post: 09-16-2010, 11:59 AM
