Hi there,
I'm having a rare WiFi connection problem when trying to get connected to an specific wireless router. On this router other devices like smartphones, and laptops can establish connection w/out problem. The issue is specific on my cell.
The same cell gets connected to any other WiFi spot I try to connect.
What I have tried so far?
* Deleting that SSID, then adding it againg to the wifi networks
* Powering off the phone, and removing that battery for around 15 min (have read it sweeps dns cache)
* Wireless router already rebooted
I also tried to install some apps to locate the issue:
* Using "Fing" it helped to make some pings and traceroutes to some public sites (so is not a connectivity issue)
* Also tried "WiFi Fixer" didn't help @ all, actually it didn't find any problem
What apparently is happening is that URLs are not being resolved by the DNS servers (they are reachable already tried that) but not resolved. :-\
My phone specs:
Model: SGS2 International (GT-i9100)
Android: 4.0.4
Any ideas on how to solve this annoying issue ??? :'(
My phone specs:
Android: 4.0.4
