1. pullmystrings's Avatar
    I purchased a Galaxy S2 from T-Mobile about a week ago, and I've noticed that when I charge it, it seems to fully charge, but as soon as I unplug it from the power source (outlet, laptop), the charge immediately drops down to 97%. This is my first smartphone, so I'm really not sure what the problem could be or if it actually is a problem. Furthermore, the battery seems to drain rather fast, in my opinion. For example, browsing Tumblr (using wifi) for approx. 20 minutes will cause the battery to go from 97% to 90%. Is this something I should be concerned about?
    07-04-2013 08:09 PM
  2. Tommy Clarkson's Avatar
    This worked for me. Let the battery drain completely.. the let it charge to 100% while off. See if that helps. Gluck!
    07-04-2013 09:42 PM
  1. Battery not fully charging and draining quickly.
    By pullmystrings in forum T-Mobile Galaxy S II
    Last Post: 10-25-2013, 03:29 PM
  2. How is your battery life?
    By neonworm in forum Droid RAZR M
    Last Post: 07-24-2013, 05:17 AM
  3. List of all prepaid plans and providers
    By petergoogle in forum General News & Discussion
    Last Post: 07-18-2013, 10:34 AM
  4. How good the battery is if you upgrade from s3 to OgPro
    By limitbreak09 in forum LG Optimus G Pro
    Last Post: 07-07-2013, 01:35 PM
  5. Like and Thanks
    By tohio in forum Site Feedback & Help
    Last Post: 07-05-2013, 12:40 PM
