1. dudesnowman's Avatar
    This is my first time posting on the forum, I'm quite desperate for help.
    So, my S2 has had a lot of problems recently with crashing and turning off etc, so I decided to do the reset. I navigated through settings and selected 'erase everything'. I'm sitting here, over 12 hours later, with my phone still displaying 'Unmounting USB storage' and I have no idea what to do. If this is normal and I just need to wait it out then that's fine, I'm just worried something has gone wrong.
    Please help!
    Thanks!
    09-06-2013 09:49 PM
  2. Golfdriver97's Avatar
    Please help!
    Thanks!
    Welcome to the forums!
    If it were me, I would pull the battery and wait a few minutes. Replace and then reboot into recovery to factory reset. However, I am not exactly sure if that is the best course of action either.
    dudesnowman likes this.
    09-06-2013 11:03 PM
  3. Ciribaski's Avatar
    Please help!
    Thanks!
    Maybe it's too late, but if you are on stock rom try resetting with kies.
    Sent from space
    09-09-2013 06:23 PM
  4. Krishna Chowdary's Avatar
    recently my S2 started getting over heated n batter drains quickly and offcourse all applications malfunction. So first I installed unwanted applications n the cleared all the cache files, but still no use
    I tried to upgrade firmware which keep telling when I connect to kies via windows PC but never completed its action. gets hang and then phone disconnects.
    after few google suggestions, I went for factory reset then try to update software through wifi but now it rejects my samsung password and says wrong password
    I tried again firm update thru kies but still same problem
    Even thou I used backup file, the phone gets overheated where quickly.
    Someone can help on this
    09-17-2013 03:20 PM
  1. Replies: 8
    Last Post: 09-23-2013, 12:52 PM
  2. Galaxy S4 premium case SALE with FREE shipping!
    By MODCASE in forum Samsung Galaxy S4
    Last Post: 09-10-2013, 03:01 AM
  3. Samsung Galaxy Ace 2 (GT-I8160) HELPPP!
    By John Matthew Reyes in forum Samsung Galaxy Ace
    Last Post: 09-08-2013, 09:31 AM
  4. Galaxy S4 bluetooth issue
    By 3amoora 8 in forum Samsung Galaxy S4
    Last Post: 09-06-2013, 09:22 PM
  5. Galaxy S4 ATT install T-mobile Stock ROM
    By tigre0540 in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 09-06-2013, 06:18 PM
