1. Incredulous16's Avatar
    Hello,
    Recently my SG2 purchased at the start of this year / end of last year from Kogan has developed a problem with the battery.
    I've noticed it's draining quicker, and then when it gets turned off it sometimes enters a cycling battery phase (vibrating every 5 - 10 seconds) and will not be turned on
    Just like the one described here
    After i connect to power it generally turns back on however with significantly less battery (sometimes taking battery out will work as well)
    (One time it went to 53% -> 2% within a matter of minutes)
    Also it seems to get very hot when vibrating and the phone does not appear to be functioning as per normal as it i had to restart it a few times before it would appear on my computer as a media device.
    I switched batteries to my mum's one (also SG2) and this does not seem to have fixed the problem, however the problem is sporadic and does not always consistently occur. When i first put my mum's battery in it turned off and on completely fine
    I have absolutely no idea what's going on and am really quite stumped... I've read on the internet about a power button malfunction but i don't think that's the case because when it finally turns on it seems to largely act normally.
    Any help would be appreciated!
    09-26-2013 06:18 PM
  2. Golfdriver97's Avatar
    Hello,
    Welcome to the forums!
    Sorry to hear about your troubles. There have been cases where the battery bulges a little and causes issues. Take it out, put it on a flat surface like a table and try to spin it. If it does, you need to replace it.
    Other wise, have you rebooted into recovery and cleared the cache?
    09-26-2013 11:29 PM
  3. Incredulous16's Avatar
    Thanks for your help! The battery does not appears to be fine, and i think it's probably a phone or charger problem because the batteries seem to work fine in my mums SG2.
    I tried clearing the cache but i don't think that has helped :\
    I'm really completely stumped by this because lots of the symptoms appear at random times inconsistently. The battery jumps around as well (sometimes going down a lot in the space of a minute when vibrating / trying to turn on and up by a bit instantly when changing sometimes...)
    Not really sure what is happening :\
    09-27-2013 01:02 AM
  4. Golfdriver97's Avatar
    Same here. Aside from a factory reset, I am unsure of anything else to suggest.
    Sent from a Slim 4.3 S3
    09-27-2013 07:21 AM
  1. My S3 is draining rapidly, even w.new battery
    By keybladeofhearts in forum AT&T Galaxy S III
    Last Post: 03-04-2014, 06:44 PM
  2. another battery post
    By conan1071 in forum Motorola Droid MAXX
    Last Post: 10-20-2013, 02:47 PM
  3. Disable Screen Dim at 15% battery?
    By Helen Keller in forum Verizon HTC One
    Last Post: 10-01-2013, 10:10 AM
  4. Galaxy Nexus Batteries losing capacity
    By trevorx3 in forum Verizon Galaxy Nexus
    Last Post: 09-26-2013, 09:57 PM
  5. Replies: 2
    Last Post: 09-26-2013, 04:16 PM
