1. developer1990's Avatar
    I have been having troubles with the phone not booting - sometimes dead, sometimes that loop between gray empty battery symbol followed by green battery and going back to gray and so on...
    I checked the battery voltage with the voltmeter and got a reading of 5.32 Volt
    Is that the problem ? Shoul the batteries not be at 3.7 V or 4.0 max ?
    Something wrong with the (external) chargers I am using ?
    10-19-2013 05:43 AM
  2. Adamsberg's Avatar
    What says the specs that are printed on the battery?
    You might load the battery with a resistor while measuring.
    10-19-2013 06:40 AM
  3. developer1990's Avatar
    It reads 3.7 V 6.11Wh
    Not sure if i understood your comment correctly - you mean the measuring with the multi-meter falsifies somehow ?
    10-19-2013 06:57 AM
  4. Adamsberg's Avatar
    I meant let flow some mA with jumping the battery with a resistor while measuring the voltage on the resistor.
    10-19-2013 08:43 AM
  5. developer1990's Avatar
    Thanks again - unfortunately I have no clue what it is that you are recommending...
    I do own that multimeter...but that's about it ;-)
    10-19-2013 09:00 AM
  6. Adamsberg's Avatar
    That multimeter, are you sure it's okay?
    For testing you could measure a alkaline battery with 1.5V ... with the multimeter's 20V range before using the 2V range.
    10-19-2013 09:26 AM
  7. developer1990's Avatar
    When I use the 2V range the reading is "1"...going back to 20V range the reading gets back to 5.3
    Has anyone tried the same with their battery ? Are you getting like 3.7 or 3.9 or maybe 4.0 max ?
    10-20-2013 06:28 AM
  8. Adamsberg's Avatar
    I meant to test your mulimeter with a alkaline 1.5V battery
    I measured some different brands of Li-Ion batteries with my multimeter: 3.7V to 3.9V
    10-20-2013 06:30 AM
  9. developer1990's Avatar
    Got it :-)
    Thanks !
    A new Duracel Alkaline MN1500 with 1.5V gives me a reading of 1,93 V
    So the multimeter is the issue...?
    Still having a hard time then to understand why the phone will boot repeatedly with one battery and go into that loop between gray and green battery with the others...
    10-20-2013 10:31 AM
  10. Adamsberg's Avatar
    ... A new Duracel Alkaline MN1500 with 1.5V gives me a reading of 1,93 V
    I think so. Is reading of 1.93V with using the 2V or the 20V range?
    Sorry, can't help you with your primary issue.
    Maybe you'd open a new thread without to mention this battery voltage.
    10-20-2013 11:08 AM
  1. Is a little light bleed normal?
    By chowdog13 in forum Google Nexus 7 Tablet (2013)
    Last Post: 12-10-2013, 03:03 PM
  2. Physically is the Nexus 5 bigger or smaller than the Nexus 4?
    By saintforlife in forum Google Nexus 5
    Last Post: 10-30-2013, 05:24 PM
  3. Replies: 6
    Last Post: 10-21-2013, 10:12 PM
  4. HTC One V - Help with battery
    By joaoareias in forum HTC One V
    Last Post: 10-21-2013, 09:30 PM
  5. google voice questions? (I hope this is the right place)
    By slave in forum General Help and How To
    Last Post: 10-20-2013, 05:23 PM
