09-15-2013 10:29 PM
80 1234
tools
  1. geekaren's Avatar
    RE 2.3.4 (KG1)
    Some AT&T users have reported difficulty connecting to AT&T data network after flashing 2.3.4. Adding a new APN (using settings in linked thread) seems to resolve the problem:
    Soluion for 2.3.4 Stock..NO Data for ATT users - xda-developers
    07-10-2011 10:58 AM
  2. chestvrg's Avatar
    After have gone from a dumb plan back to the unlimited smartphone data, I'm so happy as I had comitted the biggest mistake ever. I found this new settings to work for both internet and mms combined. Follow this settings:
    first make sure you are on a 3G or 4G data plan
    Settings are as followed:
    (any other fields not mentioned, leave blank)
    APN: Phone
    MMSC: http://mmsc.cingular.com
    MMS Proxy: wireless.cingular.com
    MMS Port: 80
    MCC: 310
    MNC: 410
    APN type: internet+mms
    So far they have been working for me and I have noticed faster data speeds as well as I'm able to send and receive mms picture msg.
    jnew4333 likes this.
    07-18-2011 06:36 PM
  3. D-Caf's Avatar
    APN: Phone
    MMS Port: 80
    MCC: 310
    MNC: 410
    i thought those settings only worked on the 4G plans. I have a 3G and have tried the APN Phone with no luck before.
    I'll try your settings as well and see if it works, though it looks like just a slight variant of the other 4G only apn settings.
    07-19-2011 01:27 PM
  4. D-Caf's Avatar
    Yep, the Phone APN still doesn't work with a 3G smartphone plan.
    07-19-2011 01:35 PM
  5. chestvrg's Avatar
    How strange because for me they are working just fine and I have at&t and I believe I'm on the right 3G or perhaps I must be in the 4G plan and that's why they work. I have to call att and know exactly which plan I'm on now.
    07-19-2011 03:11 PM
  6. Kingfrog's Avatar
    Cingular 410.wap is the MediaNet settings I am using. The "Phone" APN doesn;t work on Medianet plan but I am getting speeds just as fast as before and the handset is indicated 3G and H+. tried watching TV.com and its fine. No stuttering.
    07-19-2011 06:30 PM
  7. chestvrg's Avatar
    Do you think at&t is monitoring your data usage since you are on the media net plan? I would like to know how much data you are consuming on the media net unlimited plan monthly.
    tagle23 likes this.
    07-19-2011 06:33 PM
  8. Kingfrog's Avatar
    Well I was on the $15 200MB plan and used maybe 150mb...LOL I just don;t have to worry about it any more. I will probably use less than 2GB....in fact most of the time where I am WiFi is available.
    Im running 3G watchdog Pro..I will post what I am doing.
    I doubt with 25 million or more phones out there they will monitor my use as long as they get paid. now if they run an IEMI sweep they won;t fing my device even though I gave them the IMEI number of the SGS II when I called to cancel my data plan because I "lost my Captivate" They offered me MediatNet. OF course I took it.
    07-19-2011 06:35 PM
  9. chestvrg's Avatar
    Thank you for sharing kingfrog, Im only holding out on the unlimited smartphone data plan b/c I have hopes that at&t will grandfather us into LTE when it goes live in many parts of the country and I'll get me by then an LTE device & can you imagine unlimited LTE on at&t
    07-19-2011 06:40 PM
  10. Kingfrog's Avatar
    Now THAT would be nice. I'd hold out of I was already on a Smartphone UL data plan. I just could not justify $300+ a year for slowpoke internet when I have Wifi at home and work. and seven miles between.
    Yeah I would hold put another year or so until LTE if you are in a bigger pop area. Im in Myrtle Beach..Not the first in line...lol
    myscharnet likes this.
    07-19-2011 08:31 PM
  11. chestvrg's Avatar
    Yeah, Im in Miami, FL and I think Miami along with other metro areas will be the first recipients of the new at&t LTE network when it goes live.
    I understand those $300 extra a year, but now that LTE is just in the vicinity in my view it is worth the wait.
    07-19-2011 08:41 PM
  12. Kingfrog's Avatar
    YEah I fyou use the mobile data a lot, its worth it. I know people who don;t have cable or DSL and use their phones for Internet at home. In that case it's worth it. I am already paying $45 a month for up to 8MBPS at home. Don't need the phone's 1.5 MBPS. Work has WiFi I piggyback on as well.
    07-26-2011 09:21 PM
  13. chestvrg's Avatar
    Yeah I also have comcast for fast speed Internet at home I get like 30Mbps down and like 4Mbps up. On my Galaxy S2 I get average of 3Mbps down and 1.30 up.
    If I don't get grandfathered into an LTE unlimited plan I'll just get a non smartphone data plan of $15/mo.
    Sent from my GT-I9100
    agprime likes this.
    07-27-2011 12:51 PM
  14. Elite Busido's Avatar
    Problem with that is how are you going to be grandfathered into something that they arent going to put into the system.
    There will only be tiered LTE plans in the system, an unlimited won't exist because they never had it
    07-28-2011 03:18 AM
  15. nyc_rock's Avatar
    Whoa. Just used these setting's and 5mbps down. Fastest I had ever got before was about 3 mbps.
    More hopefull that these setting help my data connectivity issues. Most morning's I have to force the connection by enabling and disabling airplane mode. This happens when I leave my house where the phone is connected to wifi.
    07-28-2011 07:39 AM
  16. chestvrg's Avatar
    Like I said I only have hopes, in the end only at&t will decide if they'll grandfather current UL smartphone data users into a LTE UL plan.
    07-28-2011 07:54 AM
  17. Elite Busido's Avatar
    Well there has to be something to grandfather you into which there won't be. It'll be one of the ways to try and get people off of their unl data
    07-28-2011 04:54 PM
  18. chestvrg's Avatar
    Well I think it is an end game Elite, I just read on another forum that soon at&t will begin to throttle all unlimited data plans after a certain threashold.
    Here is the link: http://forums.macrumors.com/showthread.php?t=1200758
    All good things must come to an end. Now I'm going in the non-smartphone $15/month data plan.
    07-28-2011 05:12 PM
  19. Elite Busido's Avatar
    if they set it at 5gb i MIGHT be ok with that. i usually use about 4.3
    07-29-2011 02:40 AM
  20. chestvrg's Avatar
    Even tiered plans should be set at a limit of 5GB and it would be so much fare.
    07-29-2011 06:44 AM
  21. Elite Busido's Avatar
    fare? we're talking about cell phone companies
    ~_~
    07-31-2011 12:12 AM
  22. WolvesWR18's Avatar
    Hi all! Just got a galaxy s II from expansy and loving it. Only issue so far is data when H+ is not available. Phone can have full bars on regular 3g and data will not connect. This happens often when I'm indoors
    Right now I'm on ATT with 2.3.3 gingerbread. Data plan is 4g/tethering
    08-03-2011 10:20 AM
  23. D-Caf's Avatar
    Have you looked through this thread yet:
    http://forums.androidcentral.com/sam...-settings.html
    08-03-2011 11:40 AM
  24. WolvesWR18's Avatar
    Ive tried the fix posted in the sticky but no dice. Haven't read completely through the thread though so I'll check into it
    08-03-2011 12:42 PM
  25. chestvrg's Avatar
    Very strange, I hope you get this solved as the GSII (I bought mine too from expansysUSA) comes pre-installed with the media net APN settings when you put an at&t SIM. It should work everything (voice, data, sms and mms) as soon as you put in that AT&T SIM.
    08-03-2011 11:50 PM
80 1234
Tags for this Thread
