1. pcguys's Avatar
    The charger has 2 pins.
    The battery has 4 contacts.
    Which contacts should get the pins?
    Thanks!
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
    07-31-2012 08:55 AM
  2. sparksd's Avatar
    I have the Samsung charger for a spare battery and it has 3 contacts which align with the 3 outside contacts of the battery (no pin for the battery contact closest to the center of the battery).
    Dave
    07-31-2012 09:09 AM
  3. Mac.World's Avatar
    Click to view quoted image
    Thanks!
    Yes, it will. The Anker reverses polarity to charge any way you put it on. There is a pos and neg symbol on the battery. Just make sure each contact point on the anker charger touches one of them. Plug in the charger and you should have a steady red light telling you it is charging. I charged all my S2 batteries with this. No problems, other than it being a tad difficult to get the pins to line up on the contact patches onthebattery.
    07-31-2012 09:14 AM
  4. funkylogik's Avatar
    id be careful of blowing the nfc chip in the battery
    07-31-2012 12:20 PM
  5. pcguys's Avatar
    It is indeed a pain in the neck to get it to line up. I'm going to get a dedicated battery charger I can pop in without fussing.
    Thx!
    07-31-2012 12:37 PM
