Just bought a Galaxy S3 and I want to buy an extended battery, case, and car mount/charging dock. I am having trouble finding a combination of all three that will fit/work with each other. The case I am considering now is the Seidio CSK3SSGS3XK-BK because I've read it will fit the anker 4400 battery. The problem is that I can't find a car charging dock/mount to fit this case. It seems that no matter what I choose, only 2 of the 3 items I want will be compatible with each other. The case must be a sturdy kind, like the ones with silicone on the inside and a hard outer shell on the outside. The battery should be as large as possible as long as it fits in the chosen case. The car mount can be windshield mounted or maybe top dash mounted, but NOT vent mounted. I am willing to sacrifice the larger extended battery if I must, but in that case I would still like to obtain the largest mAh capacity battery that does not require changing the battery cover. Any suggestions?
