1. taylormah's Avatar
    Made by HDblog.it ..... .
    06-30-2010 01:00 AM
  2. GAMERIG's Avatar
    Yeah check out- Post#2..
    06-30-2010 02:43 AM
  3. vicw926a4's Avatar
    It looks good, and it's pretty hard to make out the video at this small scale, but that video output has to be down-rezzed to 480 lines work with a composite connection.
    07-03-2010 10:00 PM
  4. jhnstn00's Avatar
    What kind of cable was used?
    07-10-2010 02:45 PM
  5. tnayrbj's Avatar
    I just googled and found this. I am not indorsing the site I just brought it up with a google search on 3.5 mm video cables.
    Sony VMC-20FR Mini A/V Male to 3 RCA Male A/V Cable - VMC20FR -
    or
    http://www.amazon.com/gp/product/B00...acUvbUpU219457
    thanks
    Jon
    07-13-2010 01:10 PM
  6. jhnstn00's Avatar
    possibly #2 in above post or this one from android forum. Amazon.com: 6FT 3.5 mm to 3 RCA AV Camcorder Video Cable Sony JVC 6: Electronics
    #1 might be 2.5mm? looks very thin.
    07-13-2010 04:53 PM
  7. dannyc1976's Avatar
    07-24-2010 07:18 PM
  8. caliskimmer's Avatar
    Even if it has been downscaled, it doesn't look too bad in the video. What type of output does DLNA get?
    07-25-2010 12:49 AM
  9. Andrew Ruffolo's Avatar
    No. thats using the USB port, you need to use the headphone jack. The ones previously posted will work.
    07-26-2010 09:44 AM
