problem loading widget
arjayel
4
ooops i got another one...the galaxy s shows a message 'problem loading widget' but does not identify which widget nor does the pop up menu say anything that can be done about it. the home page also shows a red triangle with an exclamation point inside it (danger warning?) that doesn't want to go away, even when i close all the apps.
can anybody tell me what to do about this?
voghan
592
8
I get this on startup on occasion. Normally it will eventually start again. You might have a task killer killing it.
pierre5463
