1. mbuxx's Avatar
    I was wondering what recommendations are out there in refrence to an extended battery...im not horribly concerned about getting a new back panel as long as its not too thick as the phone is thin and light enough so I wouldnt mind
    Sent from my SGH-T959D using Tapatalk
    11-22-2010 06:42 PM
  2. josephpeter26's Avatar
    Well, I was worried about a new cover, but finally decided to buy a battery with a panel and take a risk The only reason I decided to take it is because the battery has 3000 mAh, which is double power than the original battery of the Galaxy. The cover is just a little bulky, but the result of a 3000 mah is a good satistaction.
    11-29-2010 03:32 AM
  3. mbuxx's Avatar
    Would you mind posting a pic of the phone when you get battery with new cover? I currently ordered a mugen 1600 mah with a wall charger, I figure if its no better, worst case senario I have a spare battery
    11-29-2010 03:34 PM
