1. smithe24's Avatar
    Samsung Galaxy S Duos is working very slow. I have not even installed too many apps and memory card I am using in it is just 4 GB out of it more than 2GB is still free. Still it is not working fast or normal. It is too slow to operate. What to do?
    03-08-2016 11:38 AM
  2. B. Diddy's Avatar
    Try booting into Safe Mode, which temporarily disables all 3rd party apps. The steps for the S4 should work for the Duos: https://support.t-mobile.com/docs/DOC-11724
    If the problem disappears in Safe Mode, then something you installed is causing the problem. You may have to uninstall apps one by one until the problem disappears. If the problem persists in Safe Mode, then it's more likely to be a hardware or firmware problem.
    03-08-2016 12:25 PM
  3. ChRiSt2016's Avatar
    Hi pls help I have Samsung duos model GT-S7562 if i turn the wifi on he is automatically downloading a app and he automatically install it.I think this done have a virus what I can do?
    03-13-2016 08:29 PM
  1. What Can't I Download Samsung Pay?
    By sushiguy732 in forum Samsung Galaxy S7
    Last Post: 07-22-2017, 01:20 PM
  2. How can I root my Galaxy S6 SM-G920R7
    By AC Question in forum Samsung Galaxy S6
    Last Post: 04-17-2016, 01:34 PM
  3. When can I get Galaxy S7 in Saudi Arabia?
    By AC Question in forum Samsung Galaxy S7
    Last Post: 03-09-2016, 04:26 AM
  4. S7 Edge "Always on Display" with Clear View case problem
    By Rensu in forum Samsung Galaxy S7 edge
    Last Post: 03-08-2016, 12:30 PM
