1. anon(10669147)'s Avatar
    All of this happen because I want to upgrade it into Android 4.4 (Kitkat).
    1.I successfully downgraded into stock rom/firmware (froyo) by Odin.
    2.I upgraded into custom rom/firmware (gingerbread) by samsung kies.
    3.I root a wrong root, it's for I9000 by Odin,caused it become boot stuck,but able to fix it by wiping caches & other etc.
    4.I root a correct root for SC-02B,but don't know why it make my phone soft bricked,I tried wiping caches & other etc,it doesn't work.
    5.So I decided to downgraded it into stock rom/firmware,but it make more worst, it re-partitioned finished but the PIT files,it doesn't even begin to flashing it stuck for 10 mins.
    6.I close Odin,remove the battery,& unpluged the usb.That what happen to my phone,it can only charge to a wall charger.A few weeks later I bought a very cheap JIG ordered from internet,it gave nothing but a heat to my phone, no download mode.So please anyone whoever encounter with this situation,please give a guide or instructions to fix my phone thank you.
    02-16-2020 10:51 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! I moved this from the Software Development forum to the Galaxy S forum for more specific traffic.
    02-16-2020 02:48 PM
  3. methodman89's Avatar
    It's a 10 year old phone with 512 of ram. And you rooted it. To a hungry os. I think you need a newer device. Good luck
    02-16-2020 03:56 PM
  1. Why is my S7 black screen and unresponsive?
    By jamicar in forum Ask a Question
    Last Post: 02-25-2020, 09:28 AM
  2. Has Samsung finally ditched Bixby on the S20 line?
    By PsychDoc in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 02-24-2020, 07:27 PM
  3. My touchscreen acts weird after changing the lcd display.
    By jsilvester7053 in forum Ask a Question
    Last Post: 02-20-2020, 01:52 AM
  4. I should not get any auto rejected calls in my logs . Samsung Galaxy j2 android
    Last Post: 02-17-2020, 08:37 AM
  5. How do I reset my phone
    Last Post: 02-16-2020, 03:11 PM
