03-19-2019 08:26 PM
36 12
tools
  1. justvalencia's Avatar
    Anyone has an idea if this wireless charger
    https://www.qi-infinity.com/collecti...reless-charger
    https://www.qi-infinity.com/collecti...low-qi-charger
    Will it use the full potential of the s10+ wireless charging? Also i work at home and plan to just charge my phone using a wireless charger. Would it be fine if i accidentally left my phone charging overnight? When i feel sleepy i usually go to bed and forget a few things such as removing my phone.
    03-13-2019 05:35 AM
  2. deppi0's Avatar
    As I said in another forum post:
    I just got this Anker one and I believe it is the best and fastest wireless charger available in the market for our phone. You just buy a power socket which is powerful enough though to go with it as per the description on Amazon.
    Samsung should be releasing their wireless charger soon but it seems to be a lot more expensive and same speed....
    Anker Wireless Charger with... https://www.amazon.co.uk/dp/B07GYR8S...cUvbUpU6501732
    03-14-2019 06:51 PM
  3. dirt4444's Avatar
    Can anyone tell me if the "Adaptive Fast Charger" wall plug is capable to fast charge the S10 with one of the Anker wireless chargers? I purchased one and it doesn't but that could be my issue.
    03-18-2019 10:41 AM
  4. claykin's Avatar
    You need a QC3 charger.
    03-18-2019 04:27 PM
  5. dirt4444's Avatar
    How come the charger that comes with the S10 doesn't work? That is QC2?
    03-19-2019 11:11 AM
  6. mundo472's Avatar
    Great question
    03-19-2019 11:14 AM
  7. Quixy21's Avatar
    It does work, I get wireless fast charge using my Samsung plug and Anker 10W charger.
    03-19-2019 02:11 PM
  8. claykin's Avatar
    Anker says their 10W charger requires a QC3 charger. QC3 outputs 5V, 9V and 12V. Samsung adaptive fast charger is more like QC2 which is 5V and 9V. If someone gets the Samsung charger to work as a fast charger for the Anker 10W wireless charger, then that's something to discuss with Anker.
    03-19-2019 06:26 PM
  9. Quixy21's Avatar
    Directly from the product FAQ for the 10W QI charger:
    "How fast is this PowerWave Stand?
    This PowerWave Stand features three charging speeds: 5W, 7.5W, and 10W.
    10W Fast Charge Mode {Using a QC 2.0/3.0 Adapter}"
    QC 2.0 supports 5V, 9V and 12V, up to 18W of power
    03-19-2019 06:46 PM
  10. Rose4uKY's Avatar
    So QC 2.0 does 5 and 9 and QC 3.0 does 5,9 ,and 12 is that what I am reading? Meaning QC 2.0 just may go up to 7.5 and the QC 3.0 will charge the full 10 watts? Is that correct? So to get the best out of this charger just buy any Anker charger that says QC 3.0?
    03-19-2019 08:15 PM
  11. Quixy21's Avatar
    No, see my above post. QC 2.0 does 5, 9 and 12 V and up to 18W. Samsung chargers are QC 2.0 compatible, so you'll get the full ability of a 10W charger out of it.
    03-19-2019 08:26 PM
36 12
  1. powr wireless car charger
    By Borarjti in forum Chargers and Batteries
    Last Post: Today, 09:03 AM
  2. Buy International Version : Ebay......charger compatible to U.S.
    By RB22 in forum General Help and How To
    Last Post: 02-28-2019, 04:24 PM
  3. What is the sound that the Galaxy S9 makes when charger connected?
    Last Post: 02-28-2019, 09:45 AM
  4. S10 plus fast charging tests
    By Notefan161 in forum Samsung Galaxy S10 & S10+
    Last Post: 02-27-2019, 11:00 PM
  5. Why is my charger not going in all the way
    Last Post: 02-27-2019, 08:34 AM
