1. Galaxy Note 9 Mtz's Avatar
    Hello guys, I have a Samsung S10 G973W which was updated back in January with Android 11, compilation G973WOYV4FUA2. This update granted me the Android 11 benefits but censors started failing frequently not allowing normal working for 2 days before failing again. Once I reset it the device started working normally and expected to resolve these issues with the next update but unfortunately nothing happened. Using Samsung members to ask for help only got me useless recommendations. I went back to Android 10, compilation G973WOYV4ETK1
    and the device started work normally for several weeks with no censors problems. Recently the updated G973WOYV5GUBG
    went out and I realized that is "5" GUBG instead of "4" ETK1 as the one I'm using now. I'm not sure about to go from G973WOYV5GUBG to G973WOYV4ETK1 if the censors issues and Android 11 cannot be fixed. I'll be thankful if get confirmation about the ability to roll back from "5GUBG" to "4ETK1" version if needed.
    04-08-2021 08:09 PM
  2. mustang7757's Avatar
    Sometimes you can and can't go back to last bootloader but you would have to try with Odin
    Galaxy Note 9 Mtz likes this.
    04-08-2021 09:21 PM
  3. Galaxy Note 9 Mtz's Avatar
    and I do not run the risk of damaging the device by being of different bits?
    04-08-2021 10:55 PM
  4. B. Diddy's Avatar
    I moved this from the Galaxy S forum (for the original ancient Galaxy S phone) to the S10 forum.
    04-08-2021 10:57 PM
  5. mustang7757's Avatar
    No as long as you use official samsung firmwares , if you have a lower bootloader only thing will happen is Odin won't allow u to flash it
    04-08-2021 10:57 PM
  6. Galaxy Note 9 Mtz's Avatar
    Thank's soo much
    mustang7757 likes this.
    04-08-2021 11:10 PM
  7. mustang7757's Avatar
    Thank's soo much
    Welcome, any issue let us know.
    04-08-2021 11:21 PM
  8. Galaxy Note 9 Mtz's Avatar
    I'm really dying to update, I'm just afraid that the problems with the sensors will return, mainly the automatic brightness and the proximity, those problems are very annoying and I can't go back I would hate my device and at the moment I can't buy a new one.
    04-08-2021 11:38 PM
  9. mustang7757's Avatar
    How you blocking the update? Package Disabler Pro or alliance shield?
    04-08-2021 11:54 PM
  10. Galaxy Note 9 Mtz's Avatar
    Not automatic update and select later all the tine
    04-09-2021 07:04 AM
  11. mustang7757's Avatar
    Not automatic update and select later all the tine ������
    Surprised it doesn't eventually install after certain amount of denying it.
    04-09-2021 08:59 AM
  12. Galaxy Note 9 Mtz's Avatar
    Not to me, i can try adb via uninstall com.wssyncmldm or com.sec.android.soagent.
    But i'm only select later.... until today.
    04-09-2021 09:31 AM
  13. mustang7757's Avatar
    Ok ..
    04-09-2021 03:42 PM
  1. How to transfer photos from phone to sd card in the corect order date..
    Last Post: 04-14-2021, 08:55 PM
  2. Can I set up my cell phone as a VPN server (tunnel)?
    Last Post: 04-08-2021, 01:49 PM
  3. Why when I try to send an gif it says message failed to load?plz help
    Last Post: 04-08-2021, 12:28 PM
  4. How to change always
    Last Post: 04-08-2021, 11:16 AM
  5. Cannot connect to online games
    Last Post: 04-08-2021, 11:10 AM
