1. James Burton1's Avatar
    I purchased a second hand Samsung s10 plus, the seller provided a non genuine cable and no plug.
    I'm using a Huawei super charge plug and huawei 5A cable but I have never seen it fast charging. I have changed the settings to fast charging option. It still takes ages to charge.
    Do I need to use a different plug and cable or is wireless charging a better option for me?
    Battery life is awful compared to my 6 year old huawei, is this normal?
    Hope someone can help. Thanks
    11-26-2022 07:10 AM
  2. Morty2264's Avatar
    Welcome to Android Central! If the phone you are using is second hand and a few years old, the battery life may not be as proficient. I'm not as well versed on chargers and wattages as other users here, but perhaps a Belkin charger or a Samsung charging brick will yield you more success.
    Good luck, and keep us posted!
    BEaRebel likes this.
    11-26-2022 07:28 AM
  3. mustang7757's Avatar
    I believe the s10+ needs 25w PD usb-c charger to show fast charging
    Morty2264 and BEaRebel like this.
    11-26-2022 10:46 AM
  1. Little issue on watch 5 since last update
    By james_uk in forum Samsung Galaxy Watch 5 & 5 Pro
    Last Post: 11-26-2022, 12:40 PM
  2. Hi, Please Help Me Run a Laptop in my car, with Internet
    By AndroidAndy417 in forum General Help and How To
    Last Post: 11-24-2022, 05:09 PM
  3. My phone(android) doesn’t charging
    Last Post: 11-24-2022, 12:53 PM
  4. Help! I've had a mystery notch at the top left hand corner...
    By barskin in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 11-23-2022, 08:16 AM
  5. Help! I've had a mystery notch at the top left hand corner...(double post-Ignore)
    Last Post: 11-21-2022, 01:32 PM
