    The text size of s10 plus One ui keeps changing and becoming too large to read whole text in apps like instagram and pineterest. I have tried changing the font size to smaller multiple times. But after some time the text in instagram captions becomes too large to the extent that complete sentences are not visible. While the font size spec in settings remains the same. The same problem keeps happening again and again. Is this a bug or is there a solution for this.
    03-06-2019 02:08 PM
  2. Varun Reddy Kamireddy's Avatar
    Had the same issue. Messenger, including the pop ups get really small and Instagram text gets extremely large randomly and very frequently. Not sure what's wrong with the phone or oneUI.
    03-17-2019 05:43 PM
  3. tadpoles's Avatar
    Have you tried changing the font altogether? I always use Bauhaus but there's a plethora of others too.
    03-18-2019 01:53 PM
  4. eddie31770's Avatar
    Did you figure this out? I'm having the same issue
    03-30-2019 07:37 AM
  5. chickweedblur's Avatar
    Probably unrelated to your issue but I stumbled on the fact that when using the stock messaging app that you can pinch the text within the app smaller or larger.
    brendac54 likes this.
    03-30-2019 07:50 AM
  6. eddie31770's Avatar
    I saw that too but mine is random. And it affects Instagram, Facebook, messenger, home screen , everything. Everything just gets bigger. Almost 2x
    03-30-2019 08:11 AM
  7. eddie31770's Avatar
    Well. I think I figured it out. It appears to be some sort of issue with Bluetooth. When I go tin my car this morning and was reading an email which was fine. I closed it and started my car and connected my Bluetooth. While I waited for the car to warm I opened Instagram and it was enlarged. I thought it odd so it hit me. Only thing different was Bluetooth. I turned off my Bluetooth, closed Instagram and when the Bluetooth was off and disconnected it was back to normal. I turn it back on, closed Instagram and when I reopened it? You guess it - Enlarged. Facebook? enlarged. Email? enlarged. Bluetooth on and off several times and what happens? Enlarged when on and normal when off. Not sure how this affects screen size but I am pretty sure its my issue.
    04-01-2019 07:47 AM
  8. mustang7757's Avatar
    HI , Welcome Andriod Central !
    Can follow the link below
    https://forums.androidcentral.com/sa...-randomly.html
    04-01-2019 08:10 AM
  9. brendac54's Avatar
    That was my problem the pinching it’s back to normal thank you
    mustang7757 likes this.
    04-23-2019 08:21 PM
  10. mustang7757's Avatar
    Happy to hear you got it going.
    04-23-2019 08:34 PM
  1. How is the S10 Plus compared to the Note 9? (for n9 owners)
    By Blues Fan in forum Samsung Galaxy S10 & S10+
    Last Post: 03-07-2019, 06:27 AM
  2. S10+ International Version
    By EricMartinSoCal in forum Samsung Galaxy S10 & S10+
    Last Post: 03-06-2019, 05:09 PM
  3. Unboxing of the Prism Green S10+ (Hebrew)
    By LilSweetLin in forum Samsung Galaxy S10 & S10+
    Last Post: 03-06-2019, 02:49 PM
  4. My Outlook Exchange contacts aren't syncing with my Galaxy S8+
    Last Post: 03-06-2019, 01:18 PM
