1. Chitown28's Avatar
    I was hoping my s10+ screen would look better then my s9+ but honestly i think Samsung should have kept adaptive display in the screen mode settings cause even on vivid mode with the white balance R and G set all the way down on my s10+ my s9+ screen still looks brighter and whiter which is kinda a bummer considering this screen is suppose to be better and the phone costed more money too. What do u guys think about this? put your s9+ and s10+ on full brightness and put them next to each other and you will see what i mean.
    radiospotz likes this.
    03-09-2019 02:49 PM
  2. heatherburks's Avatar
    My s10 looks way whiter and brighter. Do you have blue filter on? I have mine on standard vivid.
    03-09-2019 02:53 PM
  3. Chitown28's Avatar
    what do you other people think?
    03-10-2019 12:19 AM
  4. sergysn's Avatar
    Same here, my s8 plus brighter and whiter as well.
    03-10-2019 12:40 AM
  5. Mattsg430's Avatar
    blue light is scaled back a lot for the s10 as opposed to prior models, hence the less "white" look. however, it's a more color accurate display comparatively, and the best available as you'll see from any review.
    03-10-2019 12:48 AM
  6. sergysn's Avatar
    Yes, you are right, i just noticed the difference when comparing side by side.
    Chitown28 likes this.
    03-10-2019 01:07 AM
  7. sulla1965's Avatar
    Well I don't have my s8 anymore, and I've never owned a note 9. But the s10 screen is very bright even at 50%, I can't imagine anyone having a problem with the s10 screen brightness.
    03-10-2019 01:30 AM
  8. Rahul_1992's Avatar
    I totally agreed with your statement. "S9 screen is brighter and whiter than s10"
    03-18-2019 04:28 PM
  9. DamianP's Avatar
    my s10+ is def skewed warm no matter how I configure it compared to my note 9 and LG v40 which runs way cooler.
    03-18-2019 06:54 PM
  10. DamianP's Avatar
    Here are some comparisons to the LG V40, both at max brightness. S10+ set to vivid, default. S10+ on the LeftMy S9+ screen is brighter and whiter then my s10+ no matter how i adjust the settings?-img_20190318_195641.jpgMy S9+ screen is brighter and whiter then my s10+ no matter how i adjust the settings?-img_20190318_195614.jpgMy S9+ screen is brighter and whiter then my s10+ no matter how i adjust the settings?-img_20190318_195721.jpg
    jbjtkbw007 likes this.
    03-18-2019 07:01 PM
  11. jcp007's Avatar
    My GS10+ is brighter in direct sunlight than my GS9+.
    03-18-2019 08:10 PM
  12. dohlo's Avatar
    The screen on my 10+ seems much, much brighter and better than my S9 ever did IMO. I noticed this yesterday more than I have other days. Love how the adaptive display changes brightness so quickly when moving between shade and sun and how bright and easy to read the display is in direct sunlight
    03-19-2019 11:14 AM
  13. radiospotz's Avatar
    I finally decided to upgrade from my Note Edge which is 6 versions ago, and I noticed the brightness is about the same. I'm very disappointed because I thought it was going to be like my Samsung tab S3 screen. Which is about three versions ago. I'm very disappointed and I don't understand why the reviews from anyone did not mention this.
    09-08-2019 03:01 PM
  14. radiospotz's Avatar
    I so agree and as I mentioned it is the same brightness as my Note Edge which is about six versions ago. Very disappointed.
    09-08-2019 03:03 PM
  1. how do I stop ads from popping ip all day. at 40 a day
    Last Post: 03-09-2019, 06:12 PM
  2. How do I add tracks to my phone to transfer to my Galaxy watch?
    By Android Central Question in forum Samsung Galaxy Watch
    Last Post: 03-09-2019, 05:55 PM
  3. It's official: the new Exynos sucks
    By zipro in forum Samsung Galaxy S10 & S10+
    Last Post: 03-09-2019, 05:00 PM
  4. My samsung galaxy note 4
    Last Post: 03-09-2019, 03:26 PM
  5. Front speaker light? S10 plus
    By Android Central Question in forum Samsung Galaxy S10 & S10+
    Last Post: 03-09-2019, 02:39 PM
