bhatech
Trusted Member
Well, maybe that's where I'm going wrong.
Medium usage day on Sunday and still 44% left at 8 PM. S10+
//uploads.tapatalk-cdn.com/20190311/7e3df62b36ff74be253481096bd0c7a5.jpg
I don't know, I don't generally change any setting. All accounts auto sync, NFC, Bluetooth, WiFi everything always on, highest resolution setting, adaptive/auto brightness on, no apps disabled or anything. Only thing I haven't turned on is the always on display which I have set up tap once to show the display.How do you get only 1% on android system?
Yeah you can try that , I didn't have to.
FHD +
Hey bro, I wanted to report back. Since I put adaptive power saving mode back on and rebooted my phone, it hasn't kicked me into medium power saving mode or turned off my AOD since. So the reboot must have done the trick.
Thank you!
About 2 days and 7 SOT
How are you getting such great battery life? I don't get even close to 2 days and the most SOT I have gotten was a little over 5
As a prospective S10+ exynos purchaser it would be appreciated if people could post model & processor variant
Why what battery life you getting?U guys getting great battery life are yours unlocked or through a carrier. My note 9 is 2weeks old and battery life sucks. I just want to throw it against a wall. My 2yr old s8+ was almost as good as my new note 9. I know the s10 is newer tech then the note 9 but this is really upsetting.
