Moral of this story.....ALWAYS go for the bigger battery!
How do you get that screen on time graph?So, I've got about 4.5 hours of SOT and I'm at 58% remaining. Unplugged now for almost 24 hours.
S10+ SD855 128GB Sprint
Adaptive Battery was off, I just turned it on so maybe it will be even better?
This is the best phone I've ever owned. My S7 Edge had to be charged 3 times a day.//uploads.tapatalk-cdn.com/20190312/317d108d45927afc0b026d26a1c6513e.jpg//uploads.tapatalk-cdn.com/20190312/6637d7675f1a3eb3e5204afd421e69da.jpg
Thanks. Never knew about this screen.Hey fam, go into Digital Wellbeing in Setting, then click in the circle. It will give you a graph of the week and you can choose which day you want.
Battery is pretty underwhelming on the plus for me.
A good initial indicator for me as to how efficiently a phone is running is how well a phone does on standby doing nothing, Samsung’s have never been that great in this regard and an iPhone or Mate 20 pro for example will sit at 100% for 2 hours or more, whereas my S9 plus or Note 9 would make just over an hour. So far my S10 plus is averaging 3% an hour drain. As always I have made an effort to tweak it and am also running a package disabler.
In use it seems ok ish but standby is leaving a lot to be desired so there must be some rogue processes running, it may just be Facebook as previously both Facebook and Facebook services could be restricted in the background on the S9/Note 9 but on the S10 I have noticed that services cannot be restricted and that really could be all the difference. Looking into dev options Samsung push is another suspect, as always it is a battle on android to know exactly what is using the most power though.
I’m going to try and look into it further later
Battery life is indeed amazing. I took it off the charger yesterday AM before work and it's finally at 17%. I can't recall having an Android phone with this longevity...it certainly is refreshing.
It's about time.
Weird, mine was an official DACH version and it came with the 845The Note 8 and 9 is shipped with Exynos in Europe as well so don’t get any hopes for a snapdragon based Note 10 for Europe
Do any of you folks do what is stated in this article??? I'm going to try only because I'd like this device to last at least 3 years without too much battery degradation.
https://www.androidauthority.com/maximize-battery-life-882395/
Not sure it said background activity was on so switched it off see if that helpswhat is all that "Android System"?
