1. pootyash's Avatar
    How are folks with the "regular" S10 doing on battery life so far?
    03-13-2019 12:58 PM
  2. WizeGuyDezignz's Avatar
    Mine has been good so far, no complaints. AT&T regular S10, Always On Display is always on.
    pootyash likes this.
    03-13-2019 05:45 PM
  3. hasasimo's Avatar
    Decent. Was initially worried because it was no where near my Note 9 or OnePlus 6T. It's a little bit better than the regular S9 was. It'll get you through the day sometimes, other times you will need a refill.
    All-in-all, after owning the Plus for all of one evening I decided the extra battery life wasn't worth how easy and elegant one-hand use felt and looked on the regular S10.
    How you perceive battery life may depend a lot on which phone you're coming from.
    03-15-2019 07:07 PM
  4. Maknora's Avatar
    You guys think keeping it at fhd kills less battery?
    03-15-2019 08:36 PM
  5. hasasimo's Avatar
    Having to power fewer pixels certainly has an impact, but I don't think it's major. I keep mine at the default FHD+.
    Keep in mind that some Power Saving modes reduce the resolution, they wouldn't do that unless it has some kind of an impact. So that should answer your question.
    03-15-2019 08:41 PM
  6. pootyash's Avatar
    Good point about perception. I'm coming from an HTC 10 with a dying battery that wouldn't last a half day. For the first couple days with this S10 I'm around 40% at bedtime. So, for me, this qualifies as miraculous.
    hasasimo likes this.
    03-16-2019 08:07 AM
  1. Android Smart Lock still does not work
    By sophiegriff in forum Legacy Android & Other OS's
    Last Post: 04-10-2019, 02:54 PM
  2. Don't envy the S10 folks..
    By robinhelenehebert in forum Samsung Galaxy Note 9
    Last Post: 03-27-2019, 11:16 AM
  3. Replies: 1
    Last Post: 03-16-2019, 12:33 AM
  4. Samsung + wrong battery prediction
    Last Post: 03-13-2019, 12:29 PM
  5. Replies: 1
    Last Post: 03-13-2019, 10:26 AM
