1. felloffthetruck's Avatar
    Do you keep your AOD always on or tap to view?
    03-13-2019 07:58 PM
  2. trucksmoveamerica#AC's Avatar
    I keep mine always on, I've gotten used to it since the 8+.
    felloffthetruck likes this.
    03-13-2019 08:02 PM
  3. bhatech's Avatar
    Tap to show works great and probably going to save some battery instead of always on
    03-13-2019 08:04 PM
  4. Adam Frix's Avatar
    I *have* the big battery, I'm going to USE the big battery.
    03-13-2019 08:07 PM
  5. Liquid_Chaos87's Avatar
    "Always on display" therefore it's always on. They gave us a cool feature, I'm going to use it.
    felloffthetruck and ladyc0524 like this.
    03-13-2019 08:13 PM
  6. DWS44's Avatar
    Always on for me. I'm not one to chew up a battery anyway, so why not?
    03-13-2019 08:16 PM
  7. cohoman's Avatar
    Always on for me!
    03-13-2019 08:17 PM
  8. msm0511's Avatar
    I kept it always on on my S8+. Not sure if I will on my S10+ if it ever gets here.
    03-13-2019 08:19 PM
  9. Rose4uKY's Avatar
    I leave mine always on too!
    03-13-2019 08:20 PM
  10. Mattsg430's Avatar
    I set a custom schedule to keep it always on except from midnight to 7am. Kept noticing it won't turn off when I place the phone screen side down, hence the custom schedule to save some potential burn-in.
    03-13-2019 08:22 PM
  11. EricMartinSoCal's Avatar
    I've had it on "tap" but maybe "always" is the way to go. No screen burn issues? Does it move?
    03-13-2019 08:29 PM
  12. msm0511's Avatar
    It moves a few pixels randomly. Not enough for you to really see, but enough that burn in isn't supposed to be an issue.
    EricMartinSoCal likes this.
    03-13-2019 08:30 PM
  13. jcp007's Avatar
    Tap to wake.
    03-13-2019 08:31 PM
  14. djlee0314's Avatar
    I use AOD on a schedule, it's on from 730am-11pm everyday. A few reasons for this 1) I use the AOD that shows you your calendar events for that day which is really handy 2) Since notification sounds won't come from the phone if connected to bluetooth I like to be able to see my notifications on AOD without having to tap. I'm connected to bluetooth ear buds all day for work but don't keep them in my ears unless I'm on a call so miss the notification sound that comes from the ear buds
    03-13-2019 08:36 PM
  15. DWS44's Avatar
    Had the AOD on my S8 for two years 24/7...no signs of burn-in on it.
    03-13-2019 09:00 PM
  16. Ninjarette's Avatar
    Always on. With the notification LED gone, I need something.
    03-13-2019 09:03 PM
  17. felloffthetruck's Avatar
    I feel you on this one.
    Ninjarette likes this.
    03-13-2019 09:07 PM
  18. tcdude's Avatar
    I have it on tap
    03-13-2019 10:05 PM
  19. Tim1954's Avatar
    When aod came out, the write-ups said they use less battery, cos they only light a few pixels up and the device snoozes. If you use tap, this wakes up the phone and lights up the display.. So allegedly you use less power with it on. But is a matter of preference really...
    03-13-2019 10:28 PM
  20. m3lover1's Avatar
    I have it on tap to show. I would like to have it always on, but after noticing it doesn't turn off while in pocket. If Samsung fixes that then I'll change it back to always on
    03-14-2019 01:23 AM
  21. EricMartinSoCal's Avatar
    Interesting. So AOD uses less power & does not have a risk of screen burn? If both are true then I'm in!
    03-14-2019 01:30 AM
  22. Tim1954's Avatar
    That was the claim when it was introduced. I use mine all the time. And you can set it to what hours you want it on with some devices. It will dim etc if you have auto brightness on. Saves me waking up the phone to check time..
    03-14-2019 02:37 AM
  23. neil74's Avatar
    Always on scheduled, one of my favourite features.
    03-14-2019 02:41 AM
  24. illdini's Avatar
    If you do the math when looking at the battery screenshots, you'll see that AOD only uses 1 percent of battery every 2 hours. I leave mine on.
    Always on display - you keep "Always on" or tap?-screenshot_20190314-044357_settings.jpg
    03-14-2019 03:48 AM
  25. Notefan161's Avatar
    Always on for me
    03-14-2019 04:19 AM
  1. Android phone wifi keeps dropping, yet router is new
    Last Post: 03-15-2019, 10:54 PM
  2. How can I edit or delete contact info from the cloud on Galaxy S8
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 03-14-2019, 04:23 PM
  3. Galaxy S10 will not share videos on WhatsApp, Viber etc.
    By KrisYYC in forum Samsung Galaxy S10 & S10+
    Last Post: 03-14-2019, 07:43 AM
  4. Cannot send pictures via any app on Android
    Last Post: 03-13-2019, 09:00 PM
  5. How can I edit or delete contact info from the cloud on Galaxy S8
    Last Post: 03-13-2019, 04:35 PM
