1. shoaib shah's Avatar
    Hi
    After using my device for 7 days I have the following battery usage pattern but with one major issue which is common in the world of Android.
    I have tried to do the following to fix it but to no avail:
    Reset phone.
    Restrict background activity on the Android system.
    Clear Google services and framework cache.
    Any help is much appreciated 😁
    03-14-2019 05:53 PM
  2. EricMartinSoCal's Avatar
    Hi
    Reset phone.
    Interesting. I don't have that on my analysis.
    03-14-2019 05:59 PM
  3. NIZMOZ44's Avatar
    Hmm, yours seems higher than mine. This is a normal day for me at work.
    Attached Thumbnails S10 regular Android system battery drain-screenshot_20190314-182310_device-care.jpg   S10 regular Android system battery drain-screenshot_20190314-182243_settings.jpg
    03-14-2019 07:30 PM
  4. NIZMOZ44's Avatar
    Here is with 23% left and Android system still at 3%. Over 6 hours of sot and 16 hours on battery. Thinking you should probably reset yours and see if that helps.
    shoaib shah likes this.
    03-14-2019 11:06 PM
  5. shoaib shah's Avatar
    Here is with 23% left and Android system still at 3%. Over 6 hours of sot and 16 hours on battery. Thinking you should probably reset yours and see if that helps. https://uploads.tapatalk-cdn.com/201...60e5809d35.jpg
    I have reset the device. No luck.
    I heard you can clear system cache from recovery mode not entirely sure how to do that which may fix the issue.
    03-15-2019 02:09 AM
  6. Riduanua's Avatar
    Hi
    Do you have Google account logged in? I realised when I log out of Google account the Android system uses a lot of battery but when no Google account signed it, battery life significantly increases and also not much drain from Android system. Any solution for this?
    04-20-2019 11:54 PM
  7. Riduanua's Avatar
    How do you get this result? my android system usage is so high. Do you have google backup and restore activated in settings?
    04-21-2019 01:13 AM
  8. methodman89's Avatar
    Yes, the Android OS is multiples of normal.
    When you reset, did you also restore? If so, reset without restore, which will recycle a problem.
    1st, place the phone in Safe mode and verify its either a 3rd party application or a OS issue.
    04-21-2019 02:38 AM
  9. Jesus Delgadillo's Avatar
    Lol I feel terrible for y'all. None of my previous Galaxies from S6-S10+ and Note 5-N8 have had more than 1% of Android usage. S10 regular Android system battery drain-screenshot_20190421-015056_settings.jpeg
    04-21-2019 02:52 AM
  10. Notefan161's Avatar
    I did a reset and mine still got up to 20-23%
    Ibe had to put on medium power saving mode to keep it lower
    04-21-2019 02:56 AM
  11. methodman89's Avatar
    Lol I feel terrible for y'all. None of my previous Galaxies from S6-S10+ and Note 5-N8 have had more than 1% of Android usage. Click image for larger version.
    The OP knows there's a problem. Everyone on this thread knows there's a problem.
    It's so special that you can laugh at it while offering no advice or solution. I recommend counseling.
    Hermes Hidayat and jetpacksam like this.
    04-21-2019 06:32 AM
  12. Hermes Hidayat's Avatar
    Hi
    Reset phone.
    do you happen to use Instagram?if so disable backgroud activity for it.
    04-21-2019 11:25 AM
  13. Rukbat's Avatar
    Almost every app uses parts of Android System, so Android System uses a lot of the battery being used. But on Pi, that should still be under 10%. (5% isn't bad, it just means that some app is using processes from Android System, rather than having the code in the app. (If it had the code in the app, the app would show more battery usage. [And you'd be wasting storage by having the same procedure in 2 apps.])
    04-21-2019 02:03 PM
  14. Riduanua's Avatar
    Hi
    Reset phone.
    Did you get any solution to this problem? I'm in the same boat.
    05-05-2019 10:48 AM
  1. Android Pie Tab S3
    By Therealm80 in forum Samsung Galaxy Tab S3
    Last Post: 09-14-2019, 05:51 AM
  2. S10+ Ceramic vs. Glass Drop Test
    By LilSweetLin in forum Samsung Galaxy S10 & S10+
    Last Post: 03-14-2019, 08:45 PM
  3. Connecting my beats solo to my S10 plus
    By Notefan161 in forum Samsung Galaxy S10 & S10+
    Last Post: 03-14-2019, 05:46 PM
  4. Replies: 0
    Last Post: 03-14-2019, 04:25 PM
  5. S10 plus- ceramic or no?
    By Mrsfwh3 in forum Samsung Galaxy S10 & S10+
    Last Post: 03-14-2019, 02:47 PM
