03-18-2019 10:47 AM
29 12
tools
  1. duketreo's Avatar
    My system memory is showing about 48 GB. I have about 50GB of my own pics, videos, etc. imported from prior phone. I am using over 100 GB total already coming from a 64 GB phone. Can this be right? Thanks!
    03-14-2019 11:34 PM
  2. duketreo's Avatar
    Any thoughts if something is wrong? Here's a picture showing system memory. If it matters, it is a Verizon phone.
    Attached Thumbnails System Memory Issue?-screenshot_20190316-100729_settings.jpg
    03-16-2019 10:16 AM
  3. illdini's Avatar
    I hate when the term memory is used for what should be called storage (to me, memory = RAM).
    Anyway, it looks OK to me. If you're that concerned, maybe you should get an SD card & move your photos and videos to that (you don't want anything you want to keep stored internally - what happens if you have to get the phone replaced, or it gets reset?)
    03-16-2019 10:32 AM
  4. mustang7757's Avatar
    Check Facebook app uninstall see if storage reads correctly, another member found this issue with a poster.
    03-16-2019 10:37 AM
  5. duketreo's Avatar
    Thanks. Already uninstalled Facebook. I am just looking at that system memory of 48 GB and thinking Android used to have a much smaller footprint. It was a quarter of the size on my s6. Has it become like Windows? If I only got the 128GB version, I'd basically have the same amount of available memory as the 64GB phone I replaced. This seems strange.
    03-16-2019 11:37 AM
  6. mustang7757's Avatar
    It is strange and little high for system storage but I never owned that high of stroage to say for sure.
    03-16-2019 11:51 AM
  7. DSMpowerhousegroup's Avatar
    System memory seems to be high, but I have the 128gb version with an SD card. My system memory is showing 19gb used.
    03-16-2019 12:10 PM
  8. Adam Frix's Avatar
    Absolutely. The ignorati compound the problem by calling storage "ROM". They have no idea what they're talking about, but that doesn't stop them from blathering on in a desperate effort to gain eyeballs to the advertising that's on their web page (advertising I don't see, btw).
    03-16-2019 12:23 PM
  9. duketreo's Avatar
    Is this the case for others? Do most have about 19GB of system memory? I'd imagine my system memory should be similar regardless of the 512 GB capacity. It seems I have an extra 30GB that are unaccounted for. Should I worry?
    03-16-2019 01:48 PM
  10. Busted51's Avatar
    lol @ people calling hard drive space, memory. so the S10 has 8 gigs of storage and 128 gigs of ram??
    03-16-2019 03:16 PM
  11. duketreo's Avatar
    I get the difference and agree. However, Samsung is listing it that way. I am specifically using "system memory" and showing the picture to figure out if somehow mine is corrupted or abnormal. Thanks for any help.
    03-16-2019 05:57 PM
  12. DSMpowerhousegroup's Avatar
    You have the 512gb. That is just a fraction of used space in comparison to the storage you have. If it really does bother you. You probably have duplicate files. You'll have to dig.
    03-17-2019 01:46 PM
  13. bhatech's Avatar
    I have the US unlocked S10 128 GB and below is what it's reporting.
    So if you go settings - device care - storage it should give a break down of what's occupying space. In mine around 50% is apps and other media stuff so approximately around 20 GB of what the OS and other system stuff takes.
    03-17-2019 01:57 PM
  14. duketreo's Avatar
    Thanks for the suggestion. Unfortunately, this screen shows no duplicate files.
    Attached Thumbnails System Memory Issue?-screenshot_20190317-164402_my-files.jpg
    03-17-2019 04:46 PM
  15. duketreo's Avatar
    https://uploads.tapatalk-cdn.com/201...f4dfc249d5.jpg
    Yeah. Here's the screen. Unfortunately, the phone doesn't let me detail the "system memory" section. Thank you everybody for trying to help.
    Attached Thumbnails System Memory Issue?-screenshot_20190317-164821_device-care.jpg
    03-17-2019 04:51 PM
  16. felloffthetruck's Avatar
    My Verizon 1TB phone shows 96.5GB used and I have nothing on the phone. This seems very high to me.
    Why would the 128GB version only use 19GB or 44GB and mine is using almost 100GB?
    03-17-2019 09:06 PM
  17. bhatech's Avatar
    Hmm that's really weird
    03-17-2019 11:09 PM
  18. felloffthetruck's Avatar
    Maybe someone else with a Verizon branded phone can chime in and let us know how much storage space their device is using up?
    03-18-2019 04:12 AM
  19. Mike Dee's Avatar
    Can you post a copy of your storage screen? I'm using 86 on my 512 but its accounted for because I copied everything over from my previous device. See my results below
    03-18-2019 07:30 AM
  20. Jesus Delgadillo's Avatar
    My T-Mobile version shows this. Keep in mind every carrier has their own version of their updates and file sizes vary. System Memory Issue?-screenshot_20190318-065008_settings.jpeg
    03-18-2019 07:57 AM
  21. felloffthetruck's Avatar
    I have a few apps installed but nothing crazy.
    Here's a screenshot.
    03-18-2019 08:20 AM
  22. radgatt's Avatar
    For some perspective, this is what I have on my unlocked 1TB S10+. I am using Verizon for service.
    Attached Thumbnails System Memory Issue?-screenshot_20190318-083853_device-care.jpg
    03-18-2019 08:41 AM
  23. felloffthetruck's Avatar
    Just don't understand how the system could use 90+ GB of storage.
    If you purchased the 128GB phone you only have about 38GB of space left?
    Is it only the 512GB & 1TB models that have so much space used up right out of the box?
    03-18-2019 09:15 AM
  24. Mike Dee's Avatar
    I have a 512 and it is not using much more than my prior phone. I have a lot of apps and hi-res music files, however I am still using less than you are.
    03-18-2019 09:55 AM
  25. bhatech's Avatar
    Yes if you see my screenshot of the 128 GB and couple of others, it only has around 20 GB for the system. Not sure why that's the case in higher end storage models, but I vaguely remember something like this coming up in the Note 9 thread as well and someone had a good explanation. I'll see if I can find that later.
    03-18-2019 10:21 AM
29 12
  1. S10 regular Android system battery drain
    By shoaib shah in forum Samsung Galaxy S10 & S10+
    Last Post: 05-05-2019, 10:48 AM
  2. modify system settings lg stylo 3
    Last Post: 03-15-2019, 11:16 PM
  3. System UI tuner
    By mrm5 in forum Samsung Galaxy S10 & S10+
    Last Post: 03-15-2019, 12:26 AM
  4. System update resulted in tan tinted screen
    By pauljjr in forum Samsung Galaxy S9 & S9+
    Last Post: 03-14-2019, 08:25 PM
  5. Bluetooth issue in android pie woth s10+
    Last Post: 03-14-2019, 09:09 AM
