1. felloffthetruck's Avatar
    I have my AOD on and the whole time I'm charging the phone wireless the status and time left are displayed across the bottom of the display.
    Is this normal?
    Will it cause burn in as this writing does not move around like the AOD does?
    03-16-2019 09:39 AM
  2. Devhux's Avatar
    I find it odd how similar info is also present if by the battery level icon if that's part of the AOD you use.
    I don't think it would really cause burn-in as it's likely moving just a few pixels every now and then.
    03-16-2019 10:14 AM
  3. jcp007's Avatar
    Do you have the Tap to Wake enabled?
    03-16-2019 12:51 PM
  4. felloffthetruck's Avatar
    No, I have it set to always on.
    03-16-2019 02:14 PM
  1. Why if i reboot my huawei y 3 if it comes on my themes stops
    By Ettienne Hattingh37 in forum Ask a Question
    Last Post: 03-16-2019, 07:44 PM
  2. How do I hide an App on my Samsung A5.
    Last Post: 03-16-2019, 01:59 PM
  3. Reinstalling Google icon on home screen?
    Last Post: 03-16-2019, 06:15 AM
  4. Replies: 1
    Last Post: 03-15-2019, 11:34 PM
  5. Feedback on android central
    By Tim1954 in forum Site Feedback & Help
    Last Post: 03-15-2019, 10:07 PM
