1. Scutley's Avatar
    I was thinking of this today.
    What is the best sound setting to have to listen to music without earphone or coming through the car stereo. Just using the plain old Samsung speaker on your Samsung S10+.
    Plus is there a way you can by bypass the raising the volume notification so it doesn't show after you raise the volume so much? Plus, is there any third party apps that helps boost the sound?
    03-20-2019 01:56 PM
  2. jlangner's Avatar
    Sound Assistant by Samsung gives a lot of extra settings, not sure on boosting the sound though.
    Scutley likes this.
    03-20-2019 02:01 PM
  3. Scutley's Avatar
    I'm using that now. Just downloaded it. Thank you.
    03-20-2019 06:19 PM
  1. 3.5 jack no sound only beeping noise on the computer
    By Android Central Question in forum Nokia 6
    Last Post: 03-26-2019, 07:20 PM
  2. What is the best root for vivo v5s
    Last Post: 03-23-2019, 08:31 PM
  3. Replies: 1
    Last Post: 03-20-2019, 10:49 AM
  4. Replies: 0
    Last Post: 03-20-2019, 10:29 AM
  5. Replies: 0
    Last Post: 03-20-2019, 04:45 AM
