1. Gunrack's Avatar
    Doesn't happen all the time. Charged fine wirelessly earlier then,
    Place on wireless charger and the phone starts charging. Almost immediately I get a message that "wireless charging paused", then it starts charging again. Keeps cycling through pausing and reconnecting. About every 5 seconds.
    Anyone notice this happening? Has happened on two different chargers.
    Thanks!
    03-21-2019 03:31 PM
  2. SpookDroid's Avatar
    Do you have any case on it? Are these chargers off brand and have the right power source connected to them (some won't work properly with anything less than 2A, for instance)? Are you sure you're properly aligning the coil to the charger?
    03-21-2019 03:38 PM
  3. Gunrack's Avatar
    Case is compatible with wireless, use it all the time.
    Anker brand chargers
    Connected to Anker Quickcharge 3 power sources
    Dead center
    I know how to charge wirelessly, been doing it a long time. I had an S8+ that I traded for the S10+. I never had this issue with the S8+.
    03-21-2019 05:17 PM
  4. Sapient's Avatar
    Thanks!
    I had that problem with my 8+ on an older charger. I think agreed the Note 7, some changes where made that made older worried chargers incompatible.
    SpookDroid likes this.
    03-21-2019 05:18 PM
  5. cohoman's Avatar
    My S10 charges amazingly on my new Anker fast wireless charging pad. I don't see any disconnecting/reconnecting.
    03-21-2019 07:30 PM
  6. Hermes Hidayat's Avatar
    Thanks!
    May i know what charger and pad are you using?
    My guess is that the adaptor doesnt give enough power thus making the pad "cut off".
    Happened to my F306 when i used my Samsung charger.
    03-22-2019 07:31 AM
  7. Il_Cacciatore's Avatar
    I am having exactly the same issue. Had an S8+ for 2 years and wirelessly charged it every day with NO issue. Got an S10 last Friday and the same wireless charger is doing this "wireless charging paused" message every 5 seconds.
    04-30-2019 11:59 PM
  8. Garz's Avatar
    No issues at all. I'm using the Samsung fast wireless charger that came out last year. BB gave it to me as a package deal with my s9.
    05-01-2019 01:15 AM
  9. Hermes Hidayat's Avatar
    Thanks!
    My Mate 20 Pro used to have this problem.im sure it was the case or phone.so i tried my best everytime to put it in the specific location and works fine.btw what wireless charging pad are you using.
    05-01-2019 01:19 PM
  1. Photo watch face with time, date, steps?
    By Android Central Question in forum Samsung Galaxy Watch
    Last Post: 03-22-2019, 03:57 AM
  2. S10 or S10 Plus (Choose One)
    By bxrider117 in forum Samsung Galaxy S10 & S10+
    Last Post: 03-21-2019, 03:32 PM
  3. Random app with Android logo
    Last Post: 03-21-2019, 02:49 PM
  4. Photo watch face with time, date, steps?
    Last Post: 03-21-2019, 01:06 PM
