1. sergysn's Avatar
    Bought this charger on Amazon, description says it's 15w per side, so it should be on par with Samsung new fast 2.0 charger right?
    https://www.amazon.com/gp/aw/d/B01M5...cUvbUpU6509230
    03-21-2019 04:39 PM
  2. Rukbat's Avatar
    Samsung says Wired charging compatible with QC2.0 and Wireless charging compatible with WPC and PMA - but all Zens says is 15 Watts, so there's no way to tell if the charger is compatible or not. Some reviews say yes, some say no.
    Assuming that Samsung is being accurate, you want WPC or PMA wireless and QC 2,0 or better wired (QC 3 and QC 4 will also work). But Zens just says "Qi", and that's not necessarily QC anything, and they say nothing about their wireless spec.
    03-21-2019 05:11 PM
  3. rescuejg's Avatar
    Ridiculous all these different standards. Should be one for all phones.
    Good luck figuring it out.
    03-21-2019 06:57 PM
  4. sergysn's Avatar
    I thought its just need to be 12w or more, it's complicated.
    03-21-2019 07:42 PM
  5. cohoman's Avatar
    I've been using the Anker Wireless charging pad with my S10, and it's been working great. It provides 10W of wireless charging power to the S10 and charges amazingly quick. I'm using a Quick Charge 3.0 adapter to power it. Very nice pad with a flat rubber surface to prevent the S10 from sliding. It also has a very small indicator light.
    03-22-2019 06:57 AM
  6. Hermes Hidayat's Avatar
    https://www.amazon.com/gp/aw/d/B01M5...cUvbUpU6509731
    Erm...as for wireless charging.i use Spigen F306W.wierd thing is it works fine with a QC3 Aukey charger,but wouldnt even light up if i use the Adaptive Fast Charging charger which came with my S10+...
    03-22-2019 07:25 AM
  1. Charger
    By recDNA in forum Samsung Galaxy Note 9 Cases & Accessories
    Last Post: 04-04-2019, 08:49 PM
  2. Wireless charging problem with S10+
    By Gunrack in forum Samsung Galaxy S10 & S10+
    Last Post: 03-22-2019, 07:31 AM
  3. Notification if charger unplugs?
    Last Post: 03-21-2019, 03:42 AM
  4. wireless chargers
    By henryfool3 in forum Samsung Galaxy S10e
    Last Post: 03-20-2019, 06:23 PM
  5. AOD not displaying on Wireless Charger
    By gr8w8s in forum Samsung Galaxy S10 & S10+
    Last Post: 03-18-2019, 03:28 PM
