1. NIZMOZ44's Avatar
    Seems after the second use now my right ear on my galaxy buds is much lower in volume than my left. I've reset them, cleaned them even though they didnt need it, and talked to Samsung support which now escalated to tier 3 and waiting for an email. Seems this was a huge issue with the icon x ones and the problem now has shown up on my buds.
    Anyone else notice this yet? Also started to get static and some drop outs while phone was in my pocket cutting the yard.
    03-23-2019 08:35 PM
  2. daswooski's Avatar
    Had issue with 2018 Buds with left and it had to do with the Ambient sound setting...returned them for a new set and all is great now....
    NIZMOZ44 likes this.
    03-23-2019 08:59 PM
  3. NIZMOZ44's Avatar
    Yeah, I am curious if others have noticed the issues too.
    03-24-2019 10:27 AM
  4. mustang7757's Avatar
    I'm still waiting on mine , have you checked if there's a firmware update?
    03-24-2019 10:29 AM
  5. daswooski's Avatar
    My new ones come in next week so I'll also check it out and revert
    mustang7757 likes this.
    03-24-2019 10:34 AM
  6. mustang7757's Avatar
    Mine says ship week of March 25 so hopefully next week as well for me.
    03-24-2019 10:38 AM
  7. NIZMOZ44's Avatar
    Yes, it actually updated that part last night. But didn't help.
    03-24-2019 10:40 AM
  8. NIZMOZ44's Avatar
    Here is that topic about the Icon X 2018 buds having the same issue, but mine has that metal screen, and not removable. But it looks clean as far as I can tell.
    https://us.community.samsung.com/t5/...ar/td-p/214377
    03-24-2019 10:42 AM
  9. mustang7757's Avatar
    Is the buds 1 year warranty also?
    03-24-2019 10:52 AM
  10. NIZMOZ44's Avatar
    I would assume so. They didn't say, but when they asked for my info, they wanted the imei and wifi Mac of my s10 plus too.
    03-24-2019 10:54 AM
  11. mustang7757's Avatar
    Yeah I would assume 1 year also ..
    03-24-2019 10:58 AM
  12. LowDUB's Avatar
    any update to your issue?
    03-28-2019 09:33 AM
  13. GrooveRite's Avatar
    I'd return them for an exchange. I'd also ask them to send me the black ones for the inconvenience!
    03-28-2019 09:37 AM
  14. NIZMOZ44's Avatar
    Update: Samsung finally responded yesterday to send out replacements. They will send me a label after I receive the replacements to return the old ones. I am considering not even using them and just sell them to get a better quality pair of Bose or another brand. I did buy some Comply foam tips that seal it from getting anything into the speaker area of the headphones in case I change my mind. If not, the next owner will get those.
    Groove, not that easy when it was a promo shipped with my phone. Have to work with Samsung for a replacement.
    03-28-2019 07:38 PM
  15. anon(1733)'s Avatar
    I've had no issues with mine. Nor did I have a issue with my iconx. Guess I got lucky. Luckily I have had this problem and I've used my buds a ton since getting them. I use them everyday.
    03-28-2019 07:48 PM
  16. iast8cyclones's Avatar
    I got my son a pair. He had the problem with the left one not being as loud as the right. We returned the 1st pair for a new set and in a few weeks he was having the same problem again. I guess we'll return it for a 3rd pair. Please post here if you have any solutions.
    06-09-2019 11:45 AM
  17. jfracine's Avatar
    I had my right bud with a low volume issue for a few days. Nothing worked. I let them discharge connected to my phone during the night. Problem was solved in the morning. I tried restart, uninstalling wearable app, resetting the buds, cursing against samsung quality control, nothing worked except that. Edit: did a search my buds test and problem is not completely solved but there is clearly an improvement. Must be some dirt on the inside of my right bud who's slowly dissolving.
    06-16-2019 12:19 PM
  18. Johnston212's Avatar
    I KNEW IT! I knew that this was going to happen!
    Just to give you an idea of what to expect from here.
    If you get a warranty replacement, you can expect this exact same problem to occur on one of the earbuds within a few months.
    When you attempt to get a warranty replacement replacement, well.... You might have better luck getting Jimmy Hoffa to help you find DB Cooper.
    06-17-2019 05:43 AM
  1. How do you fix Galaxy S10 pixelated video?
    By Android Central Question in forum Samsung Galaxy S10 & S10+
    Last Post: 12-24-2019, 01:35 PM
  2. Is there a battery prob with samsung s10
    Last Post: 03-23-2019, 08:54 PM
  3. Replies: 0
    Last Post: 03-23-2019, 06:33 PM
  4. Replies: 0
  5. How do you fix Galaxy S10 pixelated video?
    Last Post: 03-23-2019, 06:15 PM
