1. lakersfreak's Avatar
    I love my S10+. Only have one issue I can't figure out.
    Is there a way to add a sound mode? All there is in the settings is Sound, Vibrate, and Mute. I would like to add a sound mode for the office so I can have all the volumes lowered while at work. The Bixby Routines is cool and I will be able to automate this function, but I need to be able to add a sound mode.
    If not possible through the phone, what app do you guys recommend? I am currently using Sound Profile but it does not work well on the S10+ at all.
    03-27-2019 12:08 PM
  2. Rukbat's Avatar
    Tasker (not free) (and you may need Secure Settings - free) will do it. IFTTT may do it (I haven't played with it much.)
    03-27-2019 12:50 PM
  3. djousma's Avatar
    I've used Tasker on my prior phone for this, and it works good. Problem is that Tasker can never go to sleep otherwise it wont see the state changes to do its automation. Turned into a battery drain on my old phone.
    I too, wish the Bixby routines would allow for controlling all the sound levels.
    03-27-2019 12:53 PM
  1. How to save and share screenshots on Samsung Galaxy Tab S 10.5 WiFi
    By Mike994 in forum General Help and How To
    Last Post: 03-30-2019, 05:39 PM
  2. does the alarm sound change when you get a new ring tone Galaxy S7
    Last Post: 03-27-2019, 01:46 PM
  3. Why The Headphones Are Getting Low Sound
    By David Wilson Finn in forum LG K7
    Last Post: 03-27-2019, 12:06 PM
  4. Why The Headphones Are Getting Low Sound
    By David Wilson Finn in forum OnePlus 6 & 6T
    Last Post: 03-27-2019, 11:51 AM
  5. Unable to find 'Show and hide button' option in Note 8 after recent update.
    Last Post: 03-26-2019, 09:26 PM
