1. tabs31's Avatar
    Is there a way to have the Always on Display turn off when the phone is turned screen down on a surface or put in your pocket? Mine stays on all the time. It doesn't shut down in these circumstances. My S8 used to.
    Thanks in advance for your assistance!
    04-25-2019 05:18 AM
  2. Hermes Hidayat's Avatar
    AOD turns off when its face down or in a pocket for more than 1min if im not wrong.try settings,display,accidental touch protection.test it out by covering the proximity sensor.
    04-25-2019 05:20 AM
  3. tabs31's Avatar
    Tried covering sensors. Didn't shut off.
    04-25-2019 05:40 AM
  4. ZOMMBIE1's Avatar
    This is a known bug and I'm hoping they push an update to fix it. Both my S9+ and Note 9's AOD turn off in my pocket or face down but the S10+ stays on no matter what. Very annoying..
    04-25-2019 05:43 AM
  5. tabs31's Avatar
    This may be an Android 9 thing as I just checked my S8 that I upgraded last week has the same issue.
    04-25-2019 06:00 AM
  6. Hermes Hidayat's Avatar
    owh dang.im sorry then.i dont use AOD...
    04-25-2019 06:03 AM
  7. mustang7757's Avatar
    You can follow this link , it talks about it
    https://forums.androidcentral.com/sa...ff-pocket.html
    04-25-2019 07:53 AM
  8. Rukbat's Avatar
    You could try using Proximity Service - it turns the screen off if something is near the proximity detector. It takes getting used to - you can't swipe down near the detector, you have to use the other side (or one side) of the top of the screen. Pick the phone up, though, and you have the screen. (And I've never seen it show up in battery usage, so it doesn't use much - it may even just set a semaphore for the sensor - if you're not putting the phone down or picking it up, it's not using battery - if you are, it only uses battery for a tiny fraction of a second.)
    04-25-2019 12:23 PM
  9. Hermes Hidayat's Avatar
    Reminds me of Gravity Screen...
    04-25-2019 01:11 PM
  10. WizeGuyDezignz's Avatar
    I installed this app and it does absolutely nothing for me. It says the service is running. I've used my hand to cover the sensor with the screen on and off. It does nothing.
    What is it supposed to do? What am I doing wrong?
    04-25-2019 06:27 PM
  11. Rukbat's Avatar
    No, when you put your hand on the screen at the top, it should turn the screen off. It does on most phones.
    04-26-2019 03:33 PM
  12. WizeGuyDezignz's Avatar
    Doesn't work for me on my S10+. Odd.
    04-26-2019 03:54 PM
  13. mustang7757's Avatar
    There's already a thread talking about this , probably be fix in future update .
    04-26-2019 04:17 PM
  14. Almeuit's Avatar
    Please see above.
    mustang7757 likes this.
    04-26-2019 04:20 PM
  1. Battery life
    By Kirstein Gourlay in forum Android Q
    Last Post: 05-18-2019, 11:06 AM
  2. Why is my s10+ on the upper part of the home screen blurry?
    By Android Central Question in forum Samsung Galaxy S10 & S10+
    Last Post: 05-01-2019, 08:51 AM
  3. Battery Light
    By Alkali in forum OnePlus 6 & 6T
    Last Post: 04-27-2019, 02:57 PM
  4. Why is my s10+ on the upper part of the home screen blurry?
    Last Post: 04-25-2019, 02:47 AM
  5. Skyline Notification over and over and over while on Phone Call
    By Steve Gonzales1 in forum Samsung Galaxy S8 & S8+
    Last Post: 04-24-2019, 11:42 PM
