I’m using android auto for navigation. When I leave the phone connect with cable to the car and navigating with the google maps. The phone screen turn off after a minutes (as I set the screen time) and the gps is also disable. The android auto screen shows GPS signal is searching because the gps on the phone was disable. If I wake up the phone screen, the gps will coming again.
How can I make the screen always on while I’m using the maps on android auto.? Or make GPS enable while I’m using android auto or while the cable is plugged in.
Ps. For general use (without android auto) I still want the gps disable while the phone sleep to save the juice.
Any suggestion? Thank you very much
05-20-2019 07:46 AM
