1. jetpacksam's Avatar
    On the s8 with Pie, I had the ability to manually control the lte int the notification area, that is not on the s10+. The WiFi controls the lte use, as it seems by default that WiFi has priority unless no signal is found. Thus, I was able to have no connections if I wanted to.
    I don't like to have the data constantly open like that, not that I'm so interesting that people will want to know what I am doing but it really eats battery life.
    Anyone know if this is still possible?
    Anyone know why they took it out?
    THank you for the site and the help.
    05-22-2019 12:18 AM
  2. Busted51's Avatar
    mobile data is indicated with a up and down arrow
    Attached Thumbnails Manual Control Of LTE-screenshot_20190522-070716_one-ui-home.jpg
    05-22-2019 06:07 AM
  3. jetpacksam's Avatar
    Yes, I know that. And that isn't in the notifications area on the s10+ Pie.
    05-22-2019 06:10 AM
  4. Busted51's Avatar
    double swipe down, hit the 3 dots.. select button order and put mobile data on the tab.
    05-22-2019 06:51 AM
  5. jetpacksam's Avatar
    Yes, I know that too and I am saying that it is not there. It's the first thing I checked.
    05-22-2019 06:54 AM
  6. Busted51's Avatar
    you can swipe for more "pages"
    05-22-2019 07:02 AM
  7. jetpacksam's Avatar
    yes, to the right. I am not an expert by any means, but i do know a bit about this and it simply is not there to be selected.
    05-22-2019 07:17 AM
  8. frederickdawg's Avatar
    It's not present on my tmobile branded s10+ either.
    05-22-2019 08:22 AM
  9. jetpacksam's Avatar
    Thank you.
    Does anyone know if this is an OS based option or do the carriers have the ability to remove/hide it?
    05-22-2019 08:25 AM
  10. bbgpsuser's Avatar
    If I understand your questions correctly, I'm pretty sure that you can do this with Samsung's "Good Lock" app.
    (1) Go to the Galaxy store -- NOT the play store
    (2) Download "Good Lock"
    (3) Open "Good Lock" and download/install "QuickStar"
    (4) Open "QuickStar" and enable it.
    (5) Click on "Visibility of Indicator Icons"
    (6) Enable the items that you want to see
    jetpacksam likes this.
    05-22-2019 12:08 PM
  11. jetpacksam's Avatar
    While I appreciate the tip, that isn't it
    In the pull down are where the airline mode indicator is, there used to be the lte up/down arrow button that allowed you to turn off lte. It was there on s8 even after the pie update.
    As @frederickdawg stated, it is not there on TMobile or on my At&T.
    I did try your suggestion. It was not the solution. the indicators on the status bar work fine.
    The button in the pull down simply is not there, therefore there is no way to disable LTE, so in order to not eat data, you have to have a valid wifi, however none of this help turn everything off. I got into the habit early on of turning off all my data when I didnt need it and imo it added 10 to the amount of time needed between charges.
    05-22-2019 12:38 PM
  12. jetpacksam's Avatar
    Now understand, you can still turn off data, but it's buried under 4 layers of menu instead of the button icon.
    This is very annoying and has to be an s10 series issue, as the s8 with Pie has the button in the drop down.
    05-22-2019 12:58 PM
  13. frederickdawg's Avatar
    I never had LTE quick toggle, but it was labelled "Mobile Data". That toggle isn't present, but was on my unlocked note 9.
    05-22-2019 01:14 PM
  14. jetpacksam's Avatar
    ok, maybe its an unlocked feature. oh thats annoying
    05-22-2019 01:16 PM
  15. bbgpsuser's Avatar
    You can create a Bixby routine that will turn off/on mobile data. You can add the icon to your screen so you don't need to speak to Bixby or dig through menus.
    05-22-2019 01:47 PM
  16. pduffer's Avatar
    I have the mobile data toggle on my unlocked S10e drop-down.
    05-22-2019 07:00 PM
  17. mustang7757's Avatar
    usually you see the data toggle on unlocked model ,most carrier phones dont have it.
    05-22-2019 09:34 PM
  18. Busted51's Avatar
    I have Verizon model and I have the option under the pull down tab.
    05-22-2019 10:29 PM
  19. mustang7757's Avatar
    I knew someone from Verizon was going to chime in lol
    frederickdawg likes this.
    05-22-2019 10:30 PM
  20. jetpacksam's Avatar
    Thank you everyone.
    That is really annoying.
    05-22-2019 11:39 PM
  21. jetpacksam's Avatar
    This works on AT&T s10+. I just did it.
    Edit:
    You will still get the annoying "Turning off Data" splash from AT&T to confirm but at least you don't have to go through the menu to turn it off.
    05-23-2019 12:30 AM
  22. frederickdawg's Avatar
    Edit:
    Great find thanks.
    At the end of the video he or she says this enables the mobile and hotspot toggles. I've already got mobile hotspot but just lack mobile data toggle. Dont want to end up with duplicate.
    05-23-2019 08:48 AM
  1. Organization of apps
    By ImTurningViolet in forum Google Pixelbook
    Last Post: 05-24-2019, 04:25 AM
  2. Replies: 1
    Last Post: 05-21-2019, 11:38 PM
  3. Replies: 0
    Last Post: 05-21-2019, 08:44 PM
  4. How do I find the *definitive* manufacture date of my S10+?
    By LilSweetLin in forum Samsung Galaxy S10 & S10+
    Last Post: 05-21-2019, 07:54 PM
