1. Hermes Hidayat's Avatar
    So been a while since ive had this issue. Wasnt bothering me but I was just wondering whether anyone else face the same issue as me?
    Everytime i charge my S10P and previous S10P with any wireless charging pad. The screen becomes very unresponsive. Not saying it doesnt respond but its like glitchy.
    06-18-2019 02:33 PM
  2. B. Diddy's Avatar
    Does this also happen with the official Samsung charging pad? I wonder if 3rd party charging pads might generate excess electromagnetic interference that impacts the touchscreen -- I think this kind of thing can happen with poor shielding of wired chargers, for example.
    06-18-2019 02:59 PM
  3. Hermes Hidayat's Avatar
    Yes in fact it does. With the single Fast Charge Pad, Fast Charge Duo Stand Type and Fast Charge Duo Pad Type... And would suddenly show"wireless charging paused" often. Wierd but it happens to all 3 of my S10P - _-
    06-18-2019 09:55 PM
  4. B. Diddy's Avatar
    Hmm. Do all of them have a screen protector? If so, try removing one and see if the problem persists on that one.
    06-18-2019 10:36 PM
  5. Hermes Hidayat's Avatar
    hi,im sorry for asking but what does the SP do?it has no connection with the charging if you ask me.if users with the SD version dont experience this.then im guessing the Exynos power surge.
    06-19-2019 01:16 AM
  6. B. Diddy's Avatar
    Admittedly, I'm grasping for straws here, since you said that all 3 S10+ phones you have exhibit the same behavior, using official Samsung wireless chargers. It seems unusual to me that something like this could've gotten past Samsung's quality control. Screen protectors can sometimes affect touch -- again, I'm speculating here, but maybe something about the screen protector is being affected by the induction coil, causing it to interfere with the touch sensitivity?
    Your theory about some Exynos issue is also interesting. I'd send some feedback to Samsung about this.
    06-19-2019 01:19 AM
  7. Hermes Hidayat's Avatar
    owh i forget to mention.my 2nd S10P was naked.same thing -_-.im guessing the proccessor...what pisses me off the most is when the phone just started charging,a text comes in.and there it goes the buggy experience -_-.
    06-19-2019 02:38 AM
  8. methodman89's Avatar
    Did you do a cache partition wipe and reboot?
    06-19-2019 05:32 AM
  9. Hermes Hidayat's Avatar
    Erm i didnt but i will try that when im back in Indonesia. But im quite sure its the hardware.
    06-19-2019 06:44 AM
  10. fuzzylumpkin's Avatar
    Patient: "doctor, my neck hurts when i tilt my head like this."
    Doctor: "then don't tilt your head like that."
    I don't think you're really supposed to use your phone while it's wireless charging... Pretty bad experience.
    That said I did just test it (I've never tried to use my phone while wireless charging, because i don't hate myself) and it worked fine... Does this happen when you've just placed it on the charger or only when it's been charging for a while?
    06-19-2019 07:12 AM
  11. mustang7757's Avatar
    Monitor this in safe mode ?
    06-19-2019 10:47 AM
  12. Hermes Hidayat's Avatar
    If i tilt my head and it hurts im pretty sure there is a problem.not like i do yoga or work in a circus.
    As for the wireless charging.i am very sure its safe to use it while charging.and with my previous wireless charging enabled devices.they work fine.this usually happens after a while.not like instantly but after a few minutes.and what you mean by because i dont hate myself?
    So youre saying if a person uses their phone while being charged wirelessly then they hate themselves?
    06-19-2019 10:52 AM
  13. Hermes Hidayat's Avatar
    I dont really understand how to use safe mode...
    And 1 more.if the phone is on the pad.and lets say im chatting on whatsapp.there would be a brief popup saying wireless charging paused.but it never actually stopped.just tested it out on 2 S10Ps...
    06-19-2019 10:54 AM
  14. mustang7757's Avatar
    Samsung Galaxy S10 - Restart in Safe Mode
    Press and hold the Power button until the 'Power off' prompt appears then release.
    Touch and hold Power off until the 'Safe mode' prompt appears then release.
    To confirm, tap Safe mode. The process may take up to 30 seconds to complete. ...
    With Safe Mode enabled, test device and app functionality.
    This will eliminate any 3rd party apps conflict , also you just restart the device to exit out.
    Is this the same wireless pad that you use it for all the phones?
    06-19-2019 10:57 AM
  15. Hermes Hidayat's Avatar
    Owh i already did that with both phones.and yes its the same.ive tried 3 different wireless chargers and yeah its the same.
    06-19-2019 10:59 AM
  16. mustang7757's Avatar
    So this rules out apps that conflict or 3rd party wireless chargers , it might be a glitch that Samsung needs to address as there really nothing much you can do as 3 phones experience this.
    06-19-2019 11:01 AM
  17. Hermes Hidayat's Avatar
    Im sure there was a thread on this.but i forgotten where.and im suspecting the Exynos.i know but was just curious.since Fast Wireless 2.0 charges the phone fast enough i can live with it.
    06-19-2019 11:03 AM
  18. mustang7757's Avatar
    I can't say for sure if it's Exynos phones as you would need more people come forward about it .
    06-19-2019 11:05 AM
  19. fuzzylumpkin's Avatar
    I didn't say using your phone while it's wireless charging wasn't safe, I said it sucked.
    My guess is heat.
    My point with the old joke you didn't get is the simplest most obvious solution is often the best. Just pick your phone up.
    06-19-2019 11:53 AM
  20. Hermes Hidayat's Avatar
    My guess is heat.
    owh dang.was a joke.im sorry i thought you were being serious.my bad -_-
    06-20-2019 01:35 AM
  1. How to wake galaxy s7 while charging to check the time?
    By zackcary in forum Samsung Galaxy S7
    Last Post: 06-24-2019, 12:23 PM
  2. Replies: 3
    Last Post: 06-18-2019, 09:56 PM
  3. Why does a background tune start playing when im talking on the phone
    Last Post: 06-18-2019, 03:00 PM
  4. Replies: 0
    Last Post: 06-18-2019, 11:18 AM
  5. Why does my V40 play the notification sound and ringtone when a call comes in?
