1. Shane Dowler's Avatar
    Hello,
    Thanks in advance for your help. I have a unlocked S10 that I bought on day one and use it with Verizon. Overall, my signal strength is 3-5 bars and live in Virginia.
    I use Nova pro as my dash. All updates are checked eveynight.
    In the last couple of weeks as I dial a phone number using Samsung dialer, it pauses and or resets on me.
    Anyone else having this issue? Mostly dialing US conference numbers.
    Shane
    06-19-2019 09:02 PM
  2. mustang7757's Avatar
    Hello,
    Shane
    Hi, I'm not experiencing this issue but you can try to long press the dialer app on the info tap on it and clear data cache then force stop see if it helps.
    06-19-2019 09:05 PM
  1. Problem with Bluetooth in Android 8.0.0
    Last Post: 06-21-2019, 12:19 AM
  2. Replies: 2
    Last Post: 06-20-2019, 12:06 AM
  3. How do you get sound when a message comes to your phone? The lgg7 thinQ
    Last Post: 06-19-2019, 10:48 PM
  4. My phone doesn't turn on-why?
    Last Post: 06-19-2019, 06:43 PM
  5. Replies: 0
    Last Post: 06-19-2019, 04:29 PM
