1. Hermes Hidayat's Avatar
    So its been awhile since using the S10 Plus and i realized Auto Brightness is utter rubbish. Always brighter than needed. Thus i often have to manually adjust the slider. Anyone has a workaround for this?
    My Note 9 auto brightness works better.
    06-20-2019 09:19 AM
  2. bassplayrguy's Avatar
    Mine works very well. I haven't noticed any difference between it and my note 9.
    06-20-2019 09:21 AM
  3. Hermes Hidayat's Avatar
    Thats just plain wierd. Before i sold my Note 9. I did put them side by side and the S10P is brighter. Already reset usage patterns so often id just turn it off now...
    06-20-2019 09:40 AM
  4. trucksmoveamerica#AC's Avatar
    I agree, the auto brightness does not work great on the S10+.
    Hermes Hidayat likes this.
    06-20-2019 12:59 PM
  5. Hermes Hidayat's Avatar
    Yes. Its always brighter than needed...
    06-20-2019 08:50 PM
  6. JHBThree's Avatar
    Android auto brightness hasn't been 'auto brightness' for at least two years. All it does is let you train the adjustment based on different lighting and it learns how you like it set. If it's too bright, it's because you need to make it lower, and then in the future the phone will know that's where you want it set in those lighting conditions.
    06-20-2019 11:42 PM
  7. mustang7757's Avatar
    Adaptive brightness now
    06-21-2019 12:04 AM
  8. trucksmoveamerica#AC's Avatar
    Give me auto brightness back.
    06-21-2019 06:04 AM
  9. JHBThree's Avatar
    This was an Android change, so unfortunately it's not coming back.
    06-21-2019 08:43 AM
  1. Does anyone else have issues with touch screen sensitivity?
    By Android Central Question in forum Samsung Galaxy S8 Active
    Last Post: 06-27-2019, 05:49 AM
  2. Shouldn't there be one forum for S10e/S10/S10+ ?
    By tgm1024 in forum Samsung Galaxy S10 & S10+
    Last Post: 06-25-2019, 08:38 AM
  3. Unlocked Galaxy S10+ wifi calling works on Verizon
    Last Post: 06-20-2019, 11:52 AM
  4. turn on auto-sync
    Last Post: 06-19-2019, 07:49 PM
  5. Does AT&T drop prices on the S10, before the Note comes out?
    By nonie in forum Samsung Galaxy S10 & S10+
    Last Post: 06-19-2019, 07:19 PM
