1. Logankk's Avatar
    I don't know if this is a problem or my heads spinning but i switched from my old iphone to the S10 and I like the phone very much i just feel like the battery is dropping too fast, about 1 percent per every 5 minutes (i use I heavily on max resolution)
    06-24-2019 08:31 AM
  2. Hermes Hidayat's Avatar
    1 percent every 5 mins means approximately 100 percent gets you 500 minutes. Which is 8 hours. Thats amazing...
    bassplayrguy and Rukbat like this.
    06-24-2019 08:53 AM
  3. Rukbat's Avatar
    Not that you should ever let the battery go down below 40%, unless you like replacing the battery.
    And to make it last even longer between charges, turn the screen brightness down and set the screen timeout to 30 seconds. There's no need for the screen (about the largest battery consumer in the phone) to be on when you're not using it.
    Edit:
    And since it's an AMOLED screen, use a dark background - it uses less battery. (I use solid black on phones with AMOLED screens.)
    06-24-2019 03:11 PM
  1. Battery Charging notification
    Last Post: 06-25-2019, 01:29 PM
  2. Replies: 1
    Last Post: 06-24-2019, 01:56 PM
  3. Will I lose all my data if i install latest firmware on my note 8?
    By Blackberry-Prince in forum General Help and How To
    Last Post: 06-24-2019, 01:54 PM
  4. what is com.qualcomm.qti.simsettings in android activity
    Last Post: 06-24-2019, 01:50 PM
  5. Replies: 1
    Last Post: 06-24-2019, 01:47 PM
