1. felloffthetruck's Avatar
    Sometimes when looking at my phone the always on display looks like the top half is cut off or blocked. Like there is an invisible notification covering the top half of the AOD.
    Tried to get a picture but as soon as I touch the phone the AOD goes back to normal.
    Anyone else seen this problem?
    07-05-2019 04:05 PM
  2. mustang7757's Avatar
    Hmm strange , haven't noticed .
    Your using good lock right? Do you use its lock screen?
    07-05-2019 04:08 PM
  3. felloffthetruck's Avatar
    Not using good lock but I do lock my phone from the edge panel sometimes.
    07-05-2019 04:25 PM
  4. mustang7757's Avatar
    How do you lock from edge panel?
    07-05-2019 04:31 PM
  5. felloffthetruck's Avatar
    Hit the lock button on the Softkey edge panel.
    07-05-2019 06:04 PM
  6. k1200s29's Avatar
    yes I am noticing the same thing oddly enough
    07-05-2019 07:04 PM
  7. mustang7757's Avatar
    I was in the edge panel didn't see this , could you show me ? Think that's pretty neat if you can do this .
    07-05-2019 07:13 PM
  8. bkeaver's Avatar
    It's an edge panel you can pick and install. I believe this is what he is referring to
    07-05-2019 07:18 PM
  9. mustang7757's Avatar
    Thanks gotcha , that's why I didn't see it , need to download in Galaxy store lol
    [IMG=509x1024]https://uploads.tapatalk-cdn.com/20190706/f0d052c74763fbbf548ff92602199f9e.jpg[/url]
    [IMG=509x1024]https://uploads.tapatalk-cdn.com/20190706/72953e9ae7de5f2d3fd9616d3adc058d.jpg[/url]
    07-05-2019 07:27 PM
  10. mustang7757's Avatar
    Kinda adds accessibility feature to it .
    07-05-2019 07:28 PM
  11. felloffthetruck's Avatar
    Yea, you have to download it like bkeaver shows above.
    This is my most used edge panel love the screen capture and lock buttons.
    mustang7757 likes this.
    07-05-2019 07:42 PM
  12. mustang7757's Avatar
    Yeah definitely pretty neat
    07-05-2019 07:45 PM
  13. felloffthetruck's Avatar
    Plus it saves wear and tear on the power button.
    07-05-2019 07:47 PM
  14. trucksmoveamerica#AC's Avatar
    This is my most used one also. I use it mainly for the screen shot.
    07-05-2019 09:41 PM
  15. asrf23632hr's Avatar
    Did you ever find out any solutions? I'm getting the same problem. Which clock are you using? I'm using the one where you can add a picture. Sometimes the top half or the bottom half gets cut off. If I tap the screen it goes back to normal
    07-06-2019 08:17 PM
  16. paulwilko10's Avatar
    This must be an issue with a latest update a si am also getting it
    S10+
    07-08-2019 09:45 AM
  1. Problem with factory reset and my SD card.
    Last Post: 07-06-2019, 04:36 PM
  2. Where did my pictures go once I backed them up on the LG G5?
    Last Post: 07-05-2019, 09:13 PM
  3. Earphones on LG G5 do not convey sound
    By Android Central Question in forum LG G5
    Last Post: 07-05-2019, 09:11 PM
  4. Font color problems after system update
    By Android Central Question in forum Samsung Galaxy J Series
    Last Post: 07-05-2019, 08:53 PM
  5. Font color problems after system update
    Last Post: 07-05-2019, 01:39 PM
