07-28-2019 02:24 PM
58 123
tools
  1. ThrowinRocks's Avatar
    you'll need to explain in more detail what you're talking about. maybe some screenshots?
    07-27-2019 06:45 AM
  2. ThrowinRocks's Avatar
    performance mode? what icon? what screen?
    07-27-2019 06:58 AM
  3. ThrowinRocks's Avatar
    Are you talking about the one in the bottom right corner?
    Attached Thumbnails Is this a Samsung s10 issue or Android Pie 9.0 issue?-screenshot_20190727-074305_google-play-services.jpg
    07-27-2019 07:45 AM
  4. methodman89's Avatar
    Yes sir. Here are some settings pages that you should confirm are correct for your needs.
    07-27-2019 08:11 AM
  5. ThrowinRocks's Avatar
    Okay. You can see the GPS Location Icon at the top on Google Maps.
    Attached Thumbnails Is this a Samsung s10 issue or Android Pie 9.0 issue?-screenshot_20190727-083726_google-play-services.jpg   Is this a Samsung s10 issue or Android Pie 9.0 issue?-screenshot_20190727-083901_settings.jpg   Is this a Samsung s10 issue or Android Pie 9.0 issue?-screenshot_20190727-083157_one-ui-home.jpg   Is this a Samsung s10 issue or Android Pie 9.0 issue?-screenshot_20190727-084450_maps.jpg
    07-27-2019 08:42 AM
  6. ThrowinRocks's Avatar
    Well I talked with Google support and Samsung support. They wanted me to send the phone in to Samsung but what will that fix? They'd just replace my new phone with a refurbished one. No Thanks.
    They both blamed the other for Smart Lock not working. Go figure.
    Had the S4, S5, S6, S7 active, S8, S9, S10 and S10+ starting with the S8 is when I had the same issues with Smart Lock.
    I guess come September I'll be using an iPhone.
    Thanks for the help.
    This thread can be officially closed
    07-27-2019 07:23 PM
  7. ThrowinRocks's Avatar
    07-27-2019 07:31 PM
  8. Rukbat's Avatar
    It's now closed.
    07-28-2019 02:24 PM
58 123
  1. I deleted data from my Android phone by mistake. How can I recover the data?
    Last Post: 07-24-2019, 12:15 PM
  2. Samsung S10 DND turns on by itself
    By Glenn Brown2 in forum Samsung Galaxy S10 & S10+
    Last Post: 07-10-2019, 11:08 PM
  3. 'Grade Scale' Going from a P30 Pro to an S10+?
    By blackhawksfan75 in forum Samsung Galaxy S10 & S10+
    Last Post: 07-10-2019, 08:31 AM
  4. S10+ won’t accept password after update
    Last Post: 07-09-2019, 05:53 PM
  5. Replies: 0
    Last Post: 07-09-2019, 04:33 PM
