Is this a Samsung s10 issue or Android Pie 9.0 issue?
Status
Not open for further replies.
ThrowinRocks
225
When trying to use Google assistant I tell it to call Dad and this is all I get. It never makes the call it just populates the screen. What the?
Yes, I've tried different contacts numbers with the same results.
Yes, I've rebooted the phone.
Yes, I've reinstalled the OS.
Adrian_luna94
3
Re: Is this a Samsung s10 issue or Android Pie 9.0 issue ?
maybe its a glitch something that didnt went well
did you ask your dad if he got your calls or if his phone is okay or not?
ThrowinRocks
225
I have his phone sitting right next to me. No issues with it whatsoever. His Google assistant works perfect. Normally when using Google assistant when you tell it to call someone it opens the phone dialer app. This stays on that screen.
rescuejg
112
Safe to assume you've tried it with other names in your directory and it behaves the same way?
ThrowinRocks
225
Here's what I posted earlier.
fuzzylumpkin
5,555
2,558
113
Hmm... I'd say it's a Google issue.
If you've factory reset it's likely a server side problem and you'll just have to wait out. You could try opting in to the beta for the Google app... Worth a shot, right?
In a likely unrelated coincidence, for the last couple of weeks if i ask Bixby (ugh) on my Galaxy Watch to "call *contact name*" it just says "*contact name* is not in your contact list" so I can relate to your frustration.
Hey! That's an idea... You can always use Bixby (ugh) as a stop gap until it starts working again... If you're a masochist lol.
ThrowinRocks
225
This is what causes me to go back to iPhones year after year. I purchased the S8 tons of issues, S9 camera was broke and sent it in for repair and they didn't fix crap it was still broke and now this software issue with the S10. lol
Maybe I need to try a different brand of Android phone.
No OnePlus whatever it has to have wireless charging and be IP67 or 68 rating.
I just don't want to go back to Apple. I like it but their prices are too high. I end up buying the iPhone, iPad and an iMac because of the ecosystem. It get's expensive. I'd prefer Android and a Chromebook or Chromebox.
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,578
6,169
113
Did you reinstall the OS by flashing it ? Or you did a factory reset?
ThrowinRocks
225
Flashing it as in holding down the buttons and bringing up the menu screen and selecting erase? Yes
Also did the factory reset.
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,578
6,169
113
Oh ok
So you cleared cache in recovery and a factory reset , flashing is through Odin the firmware , I thought maybe something went wrong if u did that , but now I know what you did .
ThrowinRocks
225
did this happen recently or its been like that for awhile Google Assistant?
No way. I won't ever flash anything. lol Bricked a phone years ago and that was it for me.
No, it's started from day three and I've owned no for 37 days. It's actually gotten worse because when it does that like what you see in the screen shot the phone will sometimes freeze up and I have to reboot it. Even after a reboot Google assistant may or may not work.
That's just adding more frustration as I had to turn off Smart lock because it never worked at my house. Even after adding like 20 location within a block. LOL
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,578
6,169
113
When you set your phone up in beginning of after the factory reset do you use smart switch?
I don't blame you not flashing after bricking your phone lol
ThrowinRocks
225
No. Even when I bought new iPhones I'd never use any old iCloud or iTunes backups or nothing like Smart Switch.
I use to take screenshots of how I had my icon layout on my old phones and just set the phone up as new and redownload the apps. I really only use like 9 apps so it's no big deal.
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,578
6,169
113
9 apps , your phone should fly with no hiccups lol
Only thing I can suggest not confident it would work , would be uninstall the Google app update and don't let it update through Google play store see if that helps . To do this is long press the Google app >info tap > 3 Dots upper right corner uninstall the update but make sure play store you don't have apps update automatically.
anon(10614692)
2,452
Well, I suggest you bite the bullet and reinstall the firmware. In your situation you can use Emergency software recovery in Samsung Smart Switch. This is specifically for Samsungs and made by Samsung, it's not some kids playing with coding so you can have the confidence in know its use will not brick your phone. It will also keep your data intact.
Status
fallingOutOfLoveWfithTech
